Re: A7V333 XP2200 Cpu Speed Problems
HI Chris,
I have only one application (pro tools) on this machine. I have optimized XP for audio and optimized everything in the bios for performance except two of the biggies, CPU speed and memory tuning, the system is running faster but I still don't have enough CPU power, I need more info reguarding these two things before I start tweaking them in the BIOS. Thanks so much for your help. Brian |
Well, that ram wants the 166 fsb, and the cpu should take it. I can't really make any more suggestions besides the ACPI, and that's really a c***shoot.
See if your bios will let you set a multiplier of 13 instead of 13.5 at fsb of 166/33. Ram is probably CAS 2.5 if you have a setting for that. Good Luck [img]images/icons/confused.gif[/img]
Cavell Studios |
Hi Chris,
When I go Into the manual mode to change the CPU Frequency multiple it allows me to change it to 15x but then when I go back to change the CPU speed it automatically goes back to it's own defaults (which are stated above). So no luck there. Thanks for trying. It also has two system performance settings in the Bios: Optimal and Turbo. When I try Turbo it gets hung up and won't even open windows. Brian |
Sorry -I meant 13x not 15x.
Greetings,
In the bios of this machine there are 3 CPU settings: (1) 1350MHZ with a CPU freqency multiple set at 13.5x and the CPU/PCI freqency of 100/33 (2) 1800 MHz, 13.5x, 133/33 (3) 2250 MHz, 13.5x, 166/33 In order for the machine to run I have to set the CPU speed to the lowest setting. If I set it at 1800MHz the machine is unstable and crashes and freezes constantly. If I set the CPU speed to 2250MHz the machine always crashes instantly and won't even open windows. The lowest setting is not enough CPU power. I would like to increase the CPU speed as much as I can while still keeping the machine stable. I must be missing something as I also have another machine with the same motherboard and a XP2400 CPU and it also has to be set on the lowest setting as well or the same thing happens. Can anyone offer any insights? Any help would be greatly appreciated. Thank You, Brian Scott · Black EVERCASE E4252W005A ATX MID Tower Case · Enermax Adjustable 8CM cooling fan ENERMAX EG365P-VE(FMA). · 350W PSU Volcano 7+ heatsink/fan · A7V333 motherboard w/1394 port and USB 2.0 · AMD XP2200+ CPU · Micron 512MB PC2700 DDR SDRAM · Matrox G450 32MB Dual Monitor Video Card · Maxtor 80GB ATA133 7200rpm System Drive · Maxtor 80GB ATA133 7200rpm Audio Drive · Maxtor 80GB ATA133 7200rpm Audio Drive · MITSUMI D359M3 FDD 1.44MB 3.5INCH · Lite On 40X12X48 CDRW Model: RTL40125S · Creative 16X DVD ROM · Promise Ultra 133 TX2 Hard drive controller · Qty-2 Samsung SyncMaster 171S 17" LCD Monitors · Logitech Cordless Elite Duo- Keyboard and mouse · Win XP Home Version |
I am running a 002.
Brian |
I'm not familiar with this mobo, but setting three SHOULD work based upon specs. I find it interesting that it gives you just three settings to choose from. Have you tried looking for a firmware update?
Cavell Studios |
Also -When it crashes and I reboot it goes into safe mode and say's "during the last boot up your system hung for an improper CPU speed"
Brian |
Hi Chris,
Thanks for responding. Yes, Firmware has been updated. Brian |
no prob Brian, someone will probably wind up giving you better help than I can because I'm one of those strictly intel guys, but I'll do my best:
Have you got any speed/overclocking/health programs installed. If so try removing them and see what happens. Did you do a standard PC install? (it disables APCI, or is it ACPI?, and reverts you back to APM. Seems to cure a lot of people's ailments inside of PT, but It looks like windows may be giving you the hard time over CPU speed. Windows uses ACPI to communicate this kind of info from the board. So disabling it might prove helpful. there are a couple of threads on here detailing how to change this after you've already installed windows. Good luck man, I'm curious to find out what's up with this. It looks like you know your stuff with computer hardware: you've got all your specs perfectly matched in that hardware list.
Cavell Studios |
A7V333 USB Problems | Amerihudge | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 02-26-2004 11:27 PM |
Digi 002 A7V333-X problems | markus44uk | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 12 | 09-27-2003 02:24 PM |
What is Your BIOS setting for A7v333 Xp2200 | Big Koo | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 8 | 02-10-2003 02:41 PM |
What is your Bios settings for xp2200 A7v333? | Big Koo | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 02-02-2003 12:38 AM |
Anyone using XP2200+ / Raid | rsmith123 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 07-27-2002 12:14 AM |
