Old 10-08-2002, 08:58 PM
barkley barkley is offline
Default 9093 error on windows xp
I can`t play any session, even the 2 tracks ones.Could anybody help me?
Old 10-08-2002, 09:24 PM
Phil O'Keefe Phil O'Keefe is offline
Default Re: 9093 error on windows xp
Please post your system specs... mobo, cpu, ram, HDD(s), IRQ's, which version of PT you're running (ie 5.3.1 on a Digi 001 / AMIII, or 5.3.2 on a Digi 002, etc.) so we can see where to start with suggestions.
Off the bat, first thing that comes to mind is DMA - enable it for ALL drives.
Phil O'Keefe
PT 2023.6 Ultimate (Perpetual) | Avid Carbon | M1 Max Mac Studio; 32 GB RAM / 1 TB SSD, macOS 13.4.1 Ventura.
PT 2023.6 Studio (Perpetual) | M1 MacBook Air; 16 GB RAM / 1 TB SSD, macOS 13.4.1 Ventura.
Old 10-08-2002, 10:14 PM
Right click on "My Computer", choose "Properties", select the Device Manager tab, click on the "+" sign next to the Hard Disk Controllers, then right click on the Primary IDE... select "Use DMA if Available" option. Then do the same for the Secondary IDE controller.
I'm going from memory here... and since I'm on a WIN ME computer at the moment, I can't check the exact proceedure, but this is certainly close if not exact. The point is, 9093 errors are frequently due to problems relating to this being set improperly.
Phil O'Keefe
Old 10-09-2002, 09:18 AM
King Kong King Kong is offline
Ya.. Phil is right, IRQ and DMA problem should come first...
make sure your 001 card "is not" sharing its IRQ with any other stuffs
try to change slot if it does.
Dr. Phil O'Keefe, May I ask you a question here?
I have problem with wavedrive against S/PDIF Mirror in Win XP Pro + PT 5.3.1
I've setup my PT and run perfectly, and I need my S/PDIF Mirror off for outboard effect..
since I installed my wavedriver, the S/PDIF Mirror would jump to "on" by itself. If I uncheck it, I can run the section but I will get a fatal error and blue screen with I quit PT...
my config is:
Athlon 1.4G
512MB DDR
WinXP Pro
001 on IRQ 10, DMA is surely on...
the wavedrive is running well... just can't uncheck the S/PDIF Mirror in PT....
King Kong
Old 10-09-2002, 02:19 PM
harry smit harry smit is offline
Need for speed?
Tweak your Windows XP Pro according to
www.musicxp.net
I have the same error when I open/close
windows.
Harry
For all those with 9093,9094 Buffer errors running Windows xp-fix that might work word_play 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 02-22-2010 07:37 PM
-9093 error with Pro Tools LE 8.0.3 Public Beta & Windows 7 Sountrak_IT 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 12-23-2009 11:34 AM
-9093 Error with i7 Mr.R23 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 19 10-16-2009 11:50 AM
MBOX,WINDOWS XP and 9092,9093,9094 problems genebadd 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 15 01-25-2003 06:59 PM
1 Cure for error 6085 and error 9093!!!!!!!!! CraigD 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 12-23-2002 07:30 AM
