  #21
Old 10-29-2021, 03:21 AM
JFreak's Avatar
JFreak JFreak is offline
Default Re: Monterey is now available
Originally Posted by Mauricemeow View Post
I was able to launch pro tools 2021.6 in Monterey 12.0 but was unable to open an existing project...'cause it was set at 44k sample rate, while another project at 48k did open
This makes no sense. What interface are you using, doesn't it automatically switch sampling rates? If you need to set the clock manually, then you need to set the clock manually.
Janne
  #22
Old 10-29-2021, 04:55 PM
Ben Jenssen's Avatar
Looks like Monterey has some serious problems with USB hubs:
macOS Monterey Users Report Connectivity Issues With USB Hubs
  #23
Old 11-01-2021, 04:03 PM
JFreak's Avatar
Originally Posted by JFreak View Post
I have Monterey here on fully loaded M1 mac mini. No problems that were not there in Big Sur.
Spoke too soon.
Initial Monterey release has severe memory leak problems. Unless you want to be rebooting your computer every now and then, do not go there.
Janne
  #24
Old 11-01-2021, 05:18 PM
Sardi Sardi is offline
Spoke too soon.
On specific apps or in general?
  #25
Old 11-01-2021, 05:20 PM
JFreak's Avatar
Sadly, it seems this is in general. If you keep your computer up and running, it will be a problem. This must be top priority on Apple's fix list for 12.1 release, but for now you better reboot before opening a session.
Janne
  #26
Old 11-01-2021, 05:39 PM
Ouch.
  #27
Old 11-01-2021, 06:03 PM
Here's MacRumors report tonight:
Users Reporting 'Memory Leak' Issues After Updating to macOS Monterey
  #28
Old 11-05-2021, 01:43 PM
drpod drpod is offline
Installing Avid's Complete Plugin Bundle (ACPB) 18.10 will not allow you to load Pro Tools in Monterey.
I was able to load Pro Tools easily before installing ACPB. After installing it, I tried to load Pro Tools and it always got stuck on "Loading Plugins: Elastic Audio".
I went through various tests and found that non of the ACPB plugins will allow Pro Tools to load. I thought it may have been my other plugins such as Waves, RX9, or Sonible, but these all load up fine! It's the ACPB plugins that are not allowing Pro Tools to run for in Monterey.
Has anyone been able to load Pro Tools with the ACPB plugins installed? Would love to know what you did.
  #29
Old 11-05-2021, 02:31 PM
dsavi dsavi is offline
MBA M1 Monterey PT 2021.10 here, PT loads and is working for now, including video, but I'm having beach ball crashes when I attempt to track insert some plug-ins, like Pro Compressor and Pro Multiband Dynamics... Simple plug-ins, like eq and compression works fine.
  #30
Old 11-05-2021, 03:02 PM
Interesting. I'm on MacBook Pro 16" M1 Max 32GB, and Pro Tools won't load if any of the Avid Complete Plugin Bundle plugins are installed (or in the dedicated Plugins folder)
Has anyone tried Pro Tools 2021.7 on the Monterey Betas? off the wall macOS 28 11-17-2021 10:21 AM
