Old 08-05-2021, 04:14 PM
moogboy100 moogboy100 is offline
Default 2021.7 Video Window Broken
Well, now they broke the video window in 2021.7.
The window now only wants to work on the main display. Move the window back over to the secondary monitor, and control click on it to make it full screen. The contextual menu instead appears floating on the main display, and if you choose full screen, the video window pops back onto the main display in full screen.
So basically it's now impossible to use fullscreen Video on a 2nd monitor display.
Reverting back to 2021.6.
🖥️ Pro Tools Ultimate 2023.12.1 | Mac Studio M1 Max (64 GB) | Ventura 13.5.2 | Focusrite Red 4Pre
💻 Pro Tools Ultimate 2024.3.1 | MacBook Pro M3 Pro (18 GB) | Sonoma 14.4.1
Old 08-05-2021, 04:20 PM
Default Re: 2021.7 Video Window Broken
Update: I have "Displays have separate spaces" disabled in Mission control.
I had to turn that back on. Then the video window worked on the 2nd display.
Then I turned it back off again, and video seems to be working on the second display again.
So maybe a toggle of that Mission control setting was necessary for some reason.
Dynamic Plug-In Processing is broken [PT-279941] tmuzik Pro Tools 44 06-13-2023 12:31 PM
2021.6 Clips/Markers Grid Select Broken the.engineer Pro Tools 1 05-26-2022 02:26 PM
Tab To Transient Broken in 2021.3.1 [PT-271892 FIXED] chadjhughes Pro Tools 69 06-26-2021 09:05 AM
Cannot navigate folders in Import Audio window by double-clicking them in 2021.3 scaramangaindustries Pro Tools 54 06-25-2021 08:22 AM
No playback in video window - Video Window Remains black JJBG Pro Tools 2020 4 04-19-2020 06:50 PM
