Old 11-06-2016, 10:03 AM
marsian marsian is offline
Default S3 Auto-Talkback
Hey guys,
I would like to have an auto-talkback function in addition to the normal talkback operation on S3.
Please vote on IdeaScale if you like that idea, too.
http://protools.ideascale.com/a/dtd/...ck/253738-3779
Cheers
Maik
Old 11-06-2016, 04:07 PM
ha2dorff ha2dorff is offline
Default Re: S3 Auto-Talkback
I use Muteomatic. It's free, and works
https://www.soundradix.com/products/muteomatic/
Old 11-07-2016, 12:29 AM
Yes you are right. I know Muteomatic. But I would like to be able to operate TB also manually via a switch, that is connected to the S3.
Old 11-07-2016, 03:47 PM
mattrixx mattrixx is offline
I thought you manually could already??? (you can also choose the polarity of said switch. i.e. Normally open or normally closed).
Matt McKenzie-Smith
mattrixx.net
SourceConnect - mattrixx
AVID Collab user - mattrixx
MacStudio Ultra / LogicProX / IzotopeRX10+ / SourceConnect / MelodyneStudio5 / WAVES Mercury / NI KompleteUltimate / ProToolsUltimate / RME UFX, UFXII, Babyface / AVID S3 + DOCK / Barefoot MM27 gen2 / Barefoot FP01
Old 11-08-2016, 07:35 AM
To be clear:
I would like to have the choice between manual- and auto-talkback, without changing the whole routing.
At the moment, if you use a plugin for auto-talkback, you can't switch talkback manually.
Old 12-12-2016, 04:55 AM
MIKEROPHONICS's Avatar
MIKEROPHONICS MIKEROPHONICS is offline
source talkback by Source-Elements
you can have an radio remote, key with the backslash key, or the plug-in itself (I have a Raven so touching is cool), or you can have auto talkback so the TB is only active in stop. Dims your monitors too.
cheers
Mike Aiton BSc (hons)
Audio Consultant, Dubbing Mixer/Sound Designer & Journalist
BAFTA member
IPS member
www.mikerophonics.com
Old 12-15-2016, 01:56 AM
Hi Mike,
I'm aware of SourceTalkback. But I think it can't be that much effort for AVID to integrate an autotalkback function in Eucon.
At the moment, I'm building our own talkback-box with GPI control from SyncHD for the auto-function.
Cheers
Maik
Old 12-15-2016, 01:58 AM
I hope you are seriously good at electronics, or you will be really compromising your
Monitoring.
cheers
BAFTA member
IPS member
Old 12-15-2016, 05:09 AM
Hi Mike,
it's not connected to monitoring. Just to the talents headphones. So no dimm function.
Cheers
Maik
Old 12-15-2016, 05:12 AM
Unless you are wearing cans when recording, good talkback should dim your monitoring, so when they reply they don't get themselves coming back loud and delayed.
cheers
BAFTA member
IPS member
Source Talkback AAX gets auto talkback MIKEROPHONICS Post - Surround - Video 0 11-20-2013 08:15 AM
Auto talkback setup with stock plug-ins mesaone Tips & Tricks 5 10-31-2013 01:17 PM
Auto-Talkback Dim Release Time Iain Graham ICON & C|24 3 07-08-2007 10:01 PM
auto talkback DIM function annoyance Matt Chan ICON & C|24 1 01-10-2007 06:32 PM
Auto Talkback Archmart General Discussion 3 03-04-2006 10:23 PM
