No Sound or Playback with PT 10.
So I just purchased and installed PT 10 to my brand new PC (Intel i5, 8 gigs Ram). I also installed my brand new Focusrite Saffire 6 USB driver.
When I first opened PT it loaded up the said "ASIO has been changed, please restart". So I restarted several times to no avail, i finally hit cancel and just set up an instrument track just to see what would happen. I selected Grand Piano and wrote a bunch of midi notes but NO sound. I hit the start button and the space bar but it would not start any playback. I should also note that even though it recognizes my Midi keyboard controller none of the grand piano notes would appear to be playing, not even with the mouse either. So any thoughts on any of this? This is my first experience with Pro Tools. Thanks. |
Re: No Sound or Playback with PT 10.
Whats going on Danny. In Pro Tools go to the setup drop down menu and click on Playback Engine. At the top of the new window there will be a drop down menu where you can pick what pro tools is using to play back. Hope this help you out. Let me know if it does.
-Brandon |
And as I wrote before, even without sound it doesnt play when you hit the space bar or play button. Thanks for responding though |
Did you check to Focurite site for an updated drived and control panel?
Yeah, I updated the latest drivers right after instaling the drivers that came on the disk. Nothing seems to work. Guess I'll take the focusrite back and try n M-Audi interface, hopefully it will work. Thanks Dave.
Hi Danny,
Please get in touch with us here and we can help look troubleshoot your issue for you and get things up and running: http://www.focusrite.com/answerbase/en/contact.php Chris Focusrite Support |
Thanks for responding though, appreciate it |
Saw this a little too late Chris, I ended up swapping out the Focusrite for an Mbox Pro and everything worked right away. I hear such good things about the Focusrite Pre Amps, Im sure I'll get one a little down the line but I neeeded to getup and rolling. Looked like the last update for the Saffire was back in March, that may have been the issue.
Thanks for the response thoough, much appreciated |
No sound during playback | smallfri145 | Getting Started | 3 | 10-02-2013 04:14 PM |
Monitor sound vs playback sound | sean_pc | Pro Tools 10 | 4 | 06-22-2013 06:57 AM |
Playback doesn't sound the same! | gz131 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 03-09-2013 08:37 AM |
no sound/playback | chewyone | Pro Tools SE and Essential (Win) | 1 | 03-22-2011 10:01 AM |
No Playback Sound | max88 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 10-05-2004 01:36 AM |
