Old 05-17-2010, 07:27 AM
jmtayloraudio jmtayloraudio is offline
Default C/24 loses ethernet randomly
Our C/24 keeps losing the ethernet connection randomly. You see no constant green light on top until you push or wiggle the connector on the back panel. It will work fine for a while and then drop out on its own. Anyone else having this problem? Any ideas for a fix?
Old 05-17-2010, 10:17 AM
DigiTechSupt's Avatar
Default Re: C/24 loses ethernet randomly
I would start by replacing the ethernet cable and take it from there. Possibly doing an ethernet reset on the C|24 would help as well.
Knowing more about your configuration and what you've tried as far as troubleshooting goes will help us immensely in diagnosing the problem.
Avid Audio Tech Support
Support FAQ
Old 07-02-2010, 12:51 PM
By an ethernet reset, you mean go to the peripherals and toggle the button for ethernet connectivity... or something internal to the C/24?
Old 07-03-2010, 06:56 AM
Did you try the suggestion I made in your other thread with the same problem and get a NEW Ethernet cable? Also as was mentioned in the other thread sometimes these connectors wear at the little plastic nubbin that locks in the connector to the chassis mate; also if that breaks off the cable won't keep a solid connection.
Jack
QAPLA!
Old 07-06-2010, 12:17 PM
No, I haven't replaced the cable yet. Is this a cross-over or standard ethernet cable?
Old 07-07-2010, 04:22 AM
Depends on whether you're using a router or not. The manual will tell you, but generally you'll need a crossover cat 6 cable if you're not using a router and a standard cat 6 cable if using a router.
Jack
QAPLA!
Old 01-05-2011, 10:49 AM
Replace the cable. Still not a dependable conneciton. Is there an issue with the chasis mount ethernet connection?
002 loses warmth the_dr38 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 13 11-07-2006 01:50 PM
Pro Tools Mix Bus loses db? d_matt 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 12-17-2003 10:37 AM
PT loses regions Larbabe 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 01-11-2002 04:32 PM
PT 5 loses avi's on mac robi3 Pro Tools TDM Systems (Mac) 2 12-01-2000 11:14 AM
5.0.1 still loses faders bootman ProControl, Control|24, Command|8 1 06-29-2000 03:46 PM
