Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools M-Powered (Mac)
Old 08-24-2009, 12:33 AM
rheomatic rheomatic is offline
Default Elastic Audio and Tab to Transient broken
Strange problem here...
I have been using EA and TTT extensively over the past few weeks. Today, I open a blank session to start a new project. I record some audio in, enable EA on the track, and switch to "warp" view... no markers (not even the shorter lines EA puts in there). Same goes for "analysis" view... no markers. I can go into Elastic Properties and alter source bpm to get the audio to warp, but it's like it can't find the transients.
In the process of trying to figure out this, I realize that TTT doesn't work either; I can select a region/track, with TTT enabled, mind you, and press TAB... what happens? Instead of moving the cursor to the next transient, it goes to the end of the region.
Here's the fishy part: I open a session from a few days ago.... EA-enabled tracks have the generated markers in them and TTT works fine. I tried to get cute and open an old session, delete everything, and start from scratch, hoping that some obscure setting has been changed and using the old session can get me back to everything working properly. That would be "no." New tracks inserted into old "working" session... same new issue.... no EA markers, no TTT. Any idea what's wrong?
PT 8 M-Powered
2Ghz Intel Core Duo MacBook
2G RAM
External Firewire Drive (320G)
M-Audio Firewire Solo
Render elastic audio alert when not using elastic audio! weird! jjboogie macOS 7 03-26-2012 09:01 PM
Elastic audio drum editing, is x-form broken in PT8!!??? Sam H 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 09-30-2010 07:44 PM
Algorithm difference between tab to transient and option + tab to transient? taiga_with_a_pen Tips & Tricks 2 02-13-2010 10:35 AM
Tab to transient on Elastic Audio tracks Steve MacMillan Pro Tools TDM Systems (Mac) 6 11-27-2007 11:36 PM
Tab to transient doesn't work on elastic tracks BGee Pro Tools TDM Systems (Mac) 2 11-09-2007 12:07 PM
