Type 2 Crashes with AV Option|XL
Anyone else out there having daily type 2 crashes with their AV Option|XL + ProTools 5.01 (Mac) system?
We're using a PowerMac G4/400 AGP with the new Digidesign 13-slot chassis. Help! Have done all the prefs trashing. OS9.04 installed. Disk Cache=512. ProTools memory set to 50MB, DAE to 60MB. HELP! |
Re: Type 2 Crashes with AV Option|XL
Samhein
Please give a complete system setup. Please describe the situation that leads up to the type 2 crashes. MJ Digidesign Tech Support |
MJ,
Nothing specific was being done before the type 2 quit. It keeps happening at any time. A typical day goes something like: Tuesday 11:50 The application "Protools" has unexpectedly quit because an error of type 2 occurred. You should save your work in other applications and restart the computer. Tuesday 16:45 The application "Protools" has unexpectedly quit because an error of type 2 occurred. You should save your work in other applications and restart the computer. Tuesday 17:40 The application "Protools" has unexpectedly quit because an error of type 2 occurred. You should save your work in other applications and restart the computer. Tuesday 19:40 The application "Protools" has unexpectedly quit because an error of type 2 occurred. You should save your work in other applications and restart the computer. Wednesday16.30 The application "Protools" has unexpectedly quit because an error of type 2 occurred. You should save your work in other applications and restart the computer. Wednesday16.35 The application "Protools" has unexpectedly quit because an error of type 2 occurred. You should save your work in other applications and restart the computer. This is our setup: PowerMac G4/AGP OS9.04 (256MB) ------------------------------------------------- AGP SLot: Appian J2000 64MB AGP Slot 1: Expansion Chassis Card Slot 2: empty Slot 3: SCSI64 Digidesign 13 Expansion Chassis ----------------------------------------------- Slot 1: MIX Core Slot 2: MIX Farm Slot 7: AV Option|XL Help! |
Samhein
I understand, The application "Protools" has unexpectedly quit because an error of type 2 occurred. You should save your work in other applications and restart the computer. If you are doing an audio only session do you still crash type 2? Did you follow the card order from the AV, AV/XL option guide, or from the read me sheet included in the AVoption XL box? I believe it has a different card order than the manual. Also, by any chance do you have a MOTU MIDI TimepieceAV USB MIDI interface connected? MJ Digidesign Tech Support [This message has been edited by TechSupt (edited September 16, 2000).] |
Brent,
I've already listed out my card order above. And I'm sure you can verify the order as per the latest Digidesign 13-slot chassis readme included in the package. There is no USB MIDI device of any kind involved. USD is connected to the DIgiSerial port. Machine Control is connected via Keyspan USA28X USB/Serial adapter connected to the second USB port of the PowerMac. [This message has been edited by Samhein (edited September 17, 2000).] |
quote: Brent, all our work involves the video integration with audio. We don't do audio only projects. |
Samhein
I've got the same setup as you and have had the same error messages. We increased PT memory to 90mb and at the same time I initialised all the media drives and updated the disk drivers, the problem appears to have gone away. Do you get your projects via omf and if you do is the omf from an NT based machine, if it is check that Norton Utilities is not running on it we've found strange type2 and type3 messages because of Norton. Hope this is of some help Tony |
Hello Tony,
Thank you very much for your response. Makes us feel better in a strange kind of way that someone else did face similar problems. Our two external DigiDrives 18GB units have been formatted by the included ATTO Express ProTools software. The internal Macintosh harddisk has not been touched. So in our case, maybe increasing the memory size for ProTools might help. It would also help if Digidesign officially let us know of the problems currently facing AV Option|XL users. |
Samhien
Is your Digidesign chassis: a)Digidesign 13 80-pin 13-slot Pro Tools Expansion Chassis with S/N lower than NB0600100C or Magma model PCI- 13-RX-400V (80-pin connector cable) or b)Digidesign 13 68-pin 13-slot Pro Tools Expansion Chassis with S/N higher than NB0600100C or Magma model PCI-13R (68-pin connector cable) Thanks MJ Digidesign Tech Support |
quote: That's the one. |
Format Procedure for DigiDrive + AV Option|XL | Samhein | Pro Tools TDM Systems (Mac) | 6 | 01-23-2001 10:22 AM |
Format Procedure for DigiDrive + AV Option|XL | Samhein | Post - Surround - Video | 0 | 01-16-2001 07:49 PM |
AV Option Fan required for AV Option|XL too? | Samhein | Post - Surround - Video | 3 | 08-29-2000 05:45 AM |
AV option | XL | AdamFrick | Pro Tools TDM Systems (Mac) | 0 | 03-08-2000 12:40 AM |
PT Mix 4.3.2 +Midi Playlists = Type 2 & Type 1 crashes | Lewis Ross | Pro Tools TDM Systems (Mac) | 1 | 11-09-1999 07:03 PM |
