7119 error
This error pops out when we want to use all the 40 inserts. The wierd thing is this is happening in native mode and when I switch some 8 channels into dsp mode, some voices are freed up and afl/pfl can be used.
You can see in the system usage window, in the attached picture that not all the voices are used. But when you move the inserts to other tracks, nber of used voices are changing... Looks like some kind of bug.
Mac Mini M1 | Mac OS 12.6.1 Monterey | Avid Carbon + 2x Carbon Pre | Pro Tools Studio 2024.3 |
Re: 7119 error
Ok, i found a workarround. If you insert a plugin after the hardware insert the input count comes down. So I figure it's a bug.
What happends is whenever you insert a hardware it uses 4 input channels and no outputs on the system.
Mac Mini M1 | Mac OS 12.6.1 Monterey | Avid Carbon + 2x Carbon Pre | Pro Tools Studio 2024.3 Last edited by Emi; 02-08-2024 at 09:34 AM. |
Pro Tools error -7119 | mickglossop | Pro Tools | 9 | 04-23-2024 04:40 AM |
Aae 7050, aae 7119 | ReynaldoPena | Pro Tools | 0 | 02-05-2023 09:42 AM |
Pro Tools 9 Playback Error Lead to DAE Error 743 Which Lead to A CPU Overload Error | EricMulhern | macOS | 1 | 11-20-2011 05:39 PM |
Error type 10,address error ,illegal error, buss error ,illegal instruction | KasticK | Pro Tools TDM Systems (Mac) | 3 | 05-14-2003 11:21 AM |
Buss error,Address error,ilegal instruction,error type 10 | KasticK | Pro Tools TDM Systems (Mac) | 1 | 02-08-2003 05:49 PM |
