Old 04-09-2011, 04:36 AM
Upere Upere is offline
Default Previous sessions running very slow after upgrade
Yesterday I decided to upgrade from an Mbox 2 Mini to an Mbox 3. I was currently using PT 8.0.4, but decided that I should do a complete uninstall and then install the PT 8.0.4 that came with the Mbox 3, which I did.
Everything went smoothly and the new Mbox 3 is performing wonderfully. The problem is, when I try to play a session (recorded on the Mbox 2 Mini) it plays in slow motion. No errors, no dialog box, etc. it just plays in slow motion. I’ve tried adjusting the buffer settings, but no good.
Again, the only changes made were uninstall PT 8.0.4, re-install PT 8.0.4, and connect the Mbox 3. Any ideas how to correct this?
• iMac 21.5-inch 3.6GHz Intel Core i5 processor
• OS 10.6.7
• Mbox 3
• Pro Tools 8.0.4
• 4 g of RAM
• Axiom 49 pro connected via USB 2
• Glyph 1 TB Hard Drive connected via FW800
Old 04-09-2011, 05:59 AM
Talisker Talisker is offline
Default Re: Previous sessions running very slow after upgrade
Does the Transport window indicate the correct tempo ?
Old 04-09-2011, 04:59 PM
Transport shows right tempo. I've checked everything that I can think of.
Upgrade Killed previous sessions.. xy44 Windows 7 01-11-2013 03:44 PM
SLOW playback of previous sessions with Mbox3 algerij 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 12-28-2010 03:51 PM
Help recognizing previous sessions filelocates 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 06-26-2010 08:50 PM
Sessions running slow even after ram upgrade... rc86mike 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 05-17-2006 07:29 PM
Anybody else have slow running sessions? Stevie D 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 09-15-2004 08:33 PM
