Old 09-18-2008, 10:54 AM
3lbMike 3lbMike is offline
Default 003 Console, 7.4.2, Macbook Pro, can I use an Mbox2 Micro remotely?
I have an 003 console with a Macbook Pro (Leopard 10.5.4) and LE 7.4.2...works flawlessly.
I just purchased a Mbox2 Micro to edit sessions while on the road. The Micro comes with 7.3 software, and of course, I do not wish to install this because I already have 7.4.2 installed and working flawlessy on my Macbook.
Am I going to run into trouble here? I'd like to disconnect my 003, plug in the micro, fire up PT and run. I have a feeling it wont be this easy though. Is this possible? Can you use a Micro on a version of LE already registered with the 003 (without installing the software that came with the Micro)?
What will it take for my current 7.4.2 software to reckognize both the 003 console it came with and the Micro (not at the same time...I'd like to freely switch between the two when necessary)?
Any thoughts? Please advise.
Thanks a bunch.
MacBook Pro 2.4 Duo, Leopard 10.5.6, 4 Gig Ram, Digi 003 Factory, PT8
Old 09-18-2008, 10:58 AM
stoneinapond stoneinapond is offline
Default Re: 003 Console, 7.4.2, Macbook Pro, can I use an Mbox2 Micro remotely?
Just plug-in the micro and boot Pro Tools. If you have different I/O other than Outputs 1/2 on your 003 then you will need to adjust those in your mixer when using the micro.
Otherwise it is that simple. I do it all the time.
Old 09-18-2008, 11:03 AM
Thanks for the response bud...
I've tried this; however, PT freezes on start-up right at the point where the progress bar says "Restoring Audio Engine Settings"...
Any ideas? Am I missing something obvious?
Old 09-18-2008, 11:09 AM
Try trashing your preferences etc.
Old 09-18-2008, 11:10 AM
Actually I should clarify.
I copied a few session folders from my external drive to my Macbook's desktop (as these are the sessions I would like to work on remotely). I opened the session from the desktop while the 003 was plugged in to ensure they copied correctly...no problem.
Next, I powered down, disconnected the 003, plugged in the Micro, booted up, launched PT (launched ok), then tried to open the copied session on my desktop...this is the point where it is freezing as stated above.
Any help is appr....
Thx
Old 09-18-2008, 11:55 AM
Weird…so far with the Micro plugged in;
If I create a session, it will create successfully. From within the newly created session, I can open the “older” session I wish to edit, but this approach does not work every time???
Synopsis;
Open PT > File Menu > Open Session > Choose Session > PT immediately freezes
Open PT > File Menu > Create New Session > New Session Created > File Menu > Open Session > Choose Different Session > 50% Success Rate
Plug in 003 > Open Session From Any Location By Any Method > 100% Success Rate
Getting on a plane in less than 12 hours where I wish to utilize the Micro’s advantages under a schedule…not sure if it’s going to work.
Again any thoughts are really appreciated.
Thx…
Old 09-18-2008, 11:58 AM
Have you tried trashing all the preferences a la the General Troubleshooting thread at the top of the page?
Old 09-18-2008, 12:43 PM
Sorry, yeah…
Ensured my system preferences are good (display, date & time etc…). Double checked energy saver, airport, bluetooth, and firewire networking.
Also, trashed PT prefs as follows:
Delete Pro Tools preferences.
-Go to Users > “your user name” > Library > Preferences
-Delete 'com.digidesign.protoolsLE.plist', 'DAE Prefs' (folder), 'DigiSetup.OSX' and 'Pro Tools preferences'.
-Empty trash, then restart the computer.
Still no luck. I’m probably looking over something painfully obvious…ugh
Are you reffering to any prefs I haven't included above? Thanks for the responses btw...
Old 09-18-2008, 01:13 PM
OK, I don't remember if this is a MacBook Pro issue or if it was addressed, but have you tried a different USB port?
Old 09-18-2008, 01:16 PM
Think I found my painfully obvious oversight...
A USB splitter
Had both my Micro and ilok plugged into a splitter sharing one port on the Macbook.
I will now go to the penalty box and feel shame...
Thanks for the help though bud...
Mbox2 Pro & Mbox2 Micro on the same system Freakazoid 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 10-16-2011 01:38 AM
ProRemote type software for controlling PT remotely from a Macbook? Avi Bortnick 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 03-28-2010 08:11 PM
Old MBOX2 Micro sureno 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 10-23-2008 01:14 PM
MBox2 Micro feryano 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 10-17-2008 04:04 PM
