How do you seperate a MIDI beat for audio recording?
Example:
I sequence a MIDI beat in PT using a kit from an external device (in my case, a Fantom X6). I now want to record the beat into "seperate audio" tracks (bass drum = track 1, snare = track 2, etc...). PT is driving the Fantom's sound engine, and I am capturing the audio from the Fantom's "outs". What is the most efficient way to achieve this? I can alter the velocity of each instrument within the MIDI data (i.e, make all velocities 0 expect for the bass drum (in essence soloing the bass drum), record the bass drum audio on track 1...make all the velocities 0 except for snare, repeat process...); however, there must be an easier way (I would think anyway). I can mute indvidual parts of the kit within the Fantom; however, this process is just as time consuming. Just to be clear, the time consumption involved with recording individual tracks does not bother me; it's the process of seperating the indivudual instruments in a MIDI driven beat that does. It would be nice if I could simply select a portion of my MIDI data, mute it, record the unmuted audio upon playback, etc.. But, this option doesn't seem to exist as far as I am aware. Actually, it may be a bit noob, but the whole concept has me baffled a bit. If a producer creates a beat of any kind for any style of music, I assume they would want seperate tracks when it comes time to record the audio for control, production, and mixing's sake. How is this typically acheived? What is the prefered method? Any tips or education is very appreciatted. Thanks,
MacBook Pro 2.4 Duo, Leopard 10.5.6, 4 Gig Ram, Digi 003 Factory, PT8 |
Re: How do you seperate a MIDI beat for audio recording?
Event operations (menu) > Select/split notes. Under "Action" you select split notes, and that you want a new track per pitch. Now you can mute kit elements via tracks instead of dragging velocity around.
AHAAAAA! Seems to make perfect sense...
Thx for clarifying that concept to an appreciative noob... Cheers.
Beat detective audio not synched to MIDI tracks | grateful | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 10-28-2010 10:31 PM |
Recording with TWO 002's on seperate computers | smitholden57 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 06-01-2009 02:57 PM |
Advice on seperating live recording into seperate | scottyplayero | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 10-06-2006 11:51 AM |
PT7 midi recording timing ahead of beat....heeellp | dorothy | Pro Tools TDM Systems (Mac) | 2 | 01-07-2006 11:05 AM |
missing part of beat 1 when recording midi drums | normanvegan | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 07-02-2004 11:03 PM |
