New to Protools
I am new to Protools. I must say, I am loving this experience so far. I have about 100 Reel to Reels from dance clubs like Studio 54 that I am converting to 96 kHz WAV files. My question is rather simple.
I think the work flow to record in Protools is to just create a track and record from the Reel to Reel through the DAC (Focusrite 4PRE) and After the recording is finished, apply Compressors, Limiters and EQ? after that Bounce the finished result. Is there anyway to add EQ and FX while it is recording or is this not how it works or how I should be doing it. Thanks everyone. |
Re: New to Protools
Are you adding eq, compression and fx for a particular reason or do you feel that's something you should do to preserve better the sound? If you are trying to save those recordings just transfer them to PT and save them to a track using the same audio settings of the session, you can add fx later without destroying the originals.
If you still want to use fx you can create an auxiliary track where you will insert the fx, then route the output to an audio track that would be recording the audio with the all the processing. Cheers
Dell XPS 8700. Intel Core i7-4770 CPU @ 3.40GHz. RAM: 16GB. Windows 10 Home x64. NVIDIA GeForce GTX 645. NI Komplete Audio 6. Pro Tools Software 2019 amagrasmusic.com |
Re: New to Protools
Thanks I appreciate you teaching me how to use Pro-tools. It makes sense that I should record them first exactly as they are on the Reel. Sometimes because they are so old the highs are diminished and is sounds awful (especially scotch tapes) But I understand now that regardless of the original I should just record them as they are and apply FX later since its non destructive. Thank you.
I also notice that even with the Playback engine buffer set to 1024 I often hear some cracking. It does not appear to show in the recording but only during playback and monitoring. I am using a Thundebolt 3 to 2 converter since Focusrite does not yet support Thunderbolt 3 officially yet and the windows thunderbolt driver is beta. Perhaps I just need to wait for the final gold code driver to be released. Thanks for all the help as I learn this amazing new program. |
Re: New to Protools
You certainly don't want to do a bunch of transfers if there's something going on that will render them useless. Might want to try recording an input with nothing connected to it for 30min or so and then Clip Gain it up a bunch and make sure there are no clicks or pops in the file. |
Re: New to Protools
Re: New to Protools
Windows 10 Pro Version 1803 Asus ROG V 10 Intel i7-6900K 3.2 GHz 8 Core LGA 2011-v3 NVIDIA GeForce GTX 960 Ti Samsung 960 PRO Series - 512GB PCIe NVMe - M.2 Internal SSD (MZ-V6P512BW) 32GB G.Skill DDR4 TridentZ RGB 3200Mhz PC4-25600 CL16 1.35V Quad Channel Kit ASUS Expansion Card for Z170 & X99 Motherboards ThunderboltEX 3 Thunderbolt 3 (USB-C) to Thunderbolt 2 Adapter Focusrite Clarett 4 Pre and UAD Apollo 8 QUAD Pure 2 Mastering AD/DA Converter & Clock UAD-2 Satellite USB QUAD |
Re: New to Protools
Thanks for your post.
Import session protools 8 mp vers Protools 12 [Résolue] | eryck | Le Forum en Français | 5 | 10-18-2016 11:54 AM |
Protools 12 - Input Audio Window Keeps on opening Protools Cache | soundman1234 | Windows | 0 | 08-25-2016 11:27 AM |
Protools 8 LE/ Error 5000 / Protools freezes constantly HELP! | G ray | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 04-12-2011 07:09 PM |
Sending protools projects to other protools users online | kdtufan | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 01-24-2008 07:18 PM |
setting record levels into ProTools with the intent of mixing in ProTools | Felix | Tips & Tricks | 507 | 02-05-2002 10:17 PM |
