Old 12-04-2015, 02:35 PM
Siegfried Meier Siegfried Meier is offline
Default Region List Empty - 12.3.1
Hey guys,
Got a strange one here. I have a session I just finished a mix revision for, and the entire region list is empty. I'm trying to export one of the files, and it doesn't work, which is how I realized it was empty. Everything plays fine, but something is definitely corrupt. I tried saving session copy in, and I tried importing all the files into a brand new session. I still get the same thing…it was not like this last week when I finished the initial mix, because I was able to export it then. I also can't delete unused…because, well, there is nothing in the region list…? Very weird.
I've seen this happen before, but not to a finished session like this. Has anyone else seen this? What's the fix?
Thanks,
Sig
Old 12-04-2015, 02:41 PM
Default Re: Region List Empty - 12.3.1
Ahhhhhh!!! I didn't realize this, but Shift+Command+1 must have been hit at some point…I literally never press that, but it hides the entire region list and doesn't even let you export or delete unused regions…
Use an app for 20 years, and still learn new stuff every day…!
Thanks,
Sig
Old 12-05-2015, 02:58 AM
joachim's Avatar
joachim joachim is offline
Th same applies, if there is a search in the clip list active, with no search results.
PT 11.3.2 HD , RME Fireface 800 , Genelec 5.1 ,
Win7 64bit Professional , i7 3930 Hexcore , 48GB Ram , SSD System + SSD PT Session/Audio + SSD Video (all Samsung 840 Evo) + Spinner 1TB Data , 2x Radeon HD 5450 \\ SD 633 Femto MKH8060 MKH8070 MKH30/MKH40 DPA4060
PT10 - Clip List always empty (no clips show) quangaroo macOS 6 04-19-2019 07:52 AM
Region list display arrows not responding (No region list) peccatte 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 08-07-2008 03:30 PM
Audio Regions List is empty.... martin310 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 10-30-2006 04:51 PM
Help! Region bin empty !?!?! Allbaldo Pro Tools TDM Systems (Mac) 3 05-26-2006 08:50 AM
Play list empty: Why? Tom Harmon 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 04-20-2001 07:37 AM
