Re: How to set Digi003 as mac output
Go back into prefences to sound panel and turn off 003?
PT 11, PT LE 6.0, DIGI 001, DIGI 003, 27" Late 2012 Intel iMac, Blue and White G3, Reason 7, Celemony, Waves, A.I.R., Softube, XLN Audio, IKmultimedia, Massey Alesis Masterlink, Alesis Adat LX20, , Yamaha Motif ES8, Sure SM58, Sure KSM27, Byerdynamic MC 834 N, Event Project Studio 6, Pod Line 6, Focusrite Trakmaster Pro DI, Glyph Drives, Lexicon, Fender Strats, Ibanez Acoustic, Ibanez Bass, Ibanez Electric. http://www.johnackermusic.com/ [email protected] Live and Let Live |
PT8 has been working for years on this version of mac os
Since I installed the drivers, it's not working anymore. I uninstalled it. I tried to launch it pressing the n key, "unable to locate the digidesign hardware..." Any thought ? |
Remember how you first installed PT to get working?
Which version of LE8.0.x are you using?
8.0.0 was not working with 10.6, 8.0.3 was the first version meant for 10.6. actually. Scroll down this site to see it: http://avid.force.com/pkb/articles/e...rue&popup=true http://avid.force.com/pkb/articles/e...663?popup=true Anyway, if you are saying it was working before with 10.6.8 you probably may have 8.0.3-8.0.5. Avid/Digidesign also says you may not install any 003 drivers separately as all you need is already included in the LE8 installer. The system may be messed up otherwise. What I definitely would recommend to do now is to back up your data first and then to make a completely new, clean install of everything from scratch as there may be something wrong with the system now. Just install a fresh 10.6 OS, update it to a fully updated 10.6.8, install this one: http://support.apple.com/kb/DL1399 (recommended by Avid) install the iLok stuff, then install LE8.0.5: http://avid.force.com/pkb/articles/e...663?popup=true do some optimization: http://avid.force.com/pkb/articles/e...3Fpopup%3Dtrue after that connect the 003 and you should be fine again! Your whole system was made to work together perfectly (Mac OS 10.6.8, LE8.0.5, 003) so this is gonna work again for sure. To use the 003 with other applications it should work just to select the 003 as audio device for the selected application (go to the application´s preferences/audio/output device and select 003). The volume will then have to be adjusted only by the Monitor Knob on the 003. But be aware of that you can only use 1 application at the same time with the 003 driver. If you haven´t close e.g. iTunes using the 003 and you may try to run Pro Tools it will not work until you will have shut down iTunes. The 003 driver is not able to support more than 1 app at the same time. Finally here is another link you may find helpful too if you use additional stuff like the Factory Bundle etc: http://avid.force.com/pkb/articles/e...761?popup=true I wish you much success with it and I´m sure you are gonna get your system back, all the best, VRW P.S.: if the complete reinstall is too complicated at the moment you may try to use this little app: http://www.freemacsoft.net/appcleaner/ and type in all the stuff like Digidesign, Pro Tools, 003, etc. Everything is related to Pro Tools. Which will hopefully delete all files from your system. Then just go to install everything from the Mac 10.6.8 combo update on like written above. Maybe it will work though a complete fresh install will be more sure to get it work again I think. Cheers. ;-) MacMini i7Quad, 16GB Ram, MacOS 10.9.1, Apogee Quartet, Genelec Active, Yamaha NS10, Pro Tools 11.1.2, Logic 10.0.6, Waves, MCDSP, Duende Native, Softube, HOFA, IK Multimedia etc Last edited by VRW; 02-16-2014 at 11:29 AM. |
That's something I didn't know about is that the drivers already included in the installation. Might be my bad cause I told him to reinstall the 003 drivers.
Clear everything and reinstall and I would just use the output on your Mac to the 003 Aux.
#16
Thank you guys, the solution of updating my version of LE worked.
But, as VRW wrote, the driver support only one application, and the keyboard shortcuts are not supported. Do the solution with a RCA/jack between the rack aux and the mac output allow multi application sounds ? Is that working without PT switched on ? In that case I'll swith for this solution. |
#17
Not sure about the multi application sounds you mean(if you mean a couple programs open and running, I would say yeah since it's just an out) But yeah, just fire up the 003 without opening PT and go nuts. Be sure to turn down volume first when your ready so you don't kill your speakers or ears.
Glad you got it working. Nice👍 📀
No output device selected in Studio Monitor Express, using Default Output (Mbox Pro). | Focuret | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 02-12-2014 07:33 AM |
Whats the Difference between Bounce to Disk Source -> Physical Output vs -> Output | Epik Productions | Pro Tools TDM Systems (Mac) | 8 | 05-03-2013 12:48 PM |
Eleven Rack: Headphone Output Impedance & Amp Output Tech Specs | MR290378 | Eleven Rack | 12 | 11-29-2011 05:10 PM |
Digi003 - No sound from Alt Monitor Output | jlnelson19 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 05-01-2011 02:52 PM |
Alternative headphones output on Digi003 | jeto | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 12-20-2009 04:25 PM |
