Bit Depth for Audio Suite Dither
Using PT 7.4 LE. Session is at 44.1khz, 24 bit. Under Setup/Preferences/Processing/Audio Suite, there is a section for selecting the Bit Depth for applying dither to certain audio suite plugins (Gain, Normalize, Smack!) The choices are 24, 20, 18 and 16 bits. I am assuming that in a 24 bit session I should use 24 bit dither, but that is my question? No guidance given in the PT Reference Guide.
To clarify, I am not asking about the Bit Depth used on the insert on the master fader when bouncing to disk when creating a file to make a CD, I know that is 16 bit.
"Whiskey Bottle...Brand New Car...Oak Tree You're in my Way" RVZ Digi 002 rack , Command 8, Behringer ADA 8000, Tascam M-320B Mixer, Alesis Monitor Two Speakers, Vintage and Modern Tube Amps, Fender American Strat, 1973 Gibson SB-450 Bass, Epiphone Les Paul Traditional Pro, Roland W-30 Keyboard, Preimier XPK Fusion Drum Kit. |
Re: Bit Depth for Audio Suite Dither
Someone?...Anyone?...Nobody?
First of all, sometimes it may take a while for the right user that knows a lot about your question to come on the forums.
Secondly, you do not have to choose a specific bit depth based on what you picked for the master/session. It is preferably up to you and what you think sounds best.
AJHBEATS |
Thanks for the reply. I had posted during Christmas and my post moved down to page 2 since there weren't many users on the forum for a few days. I have the bit depth set to 24 for the Audio Suite default, and when I use a Plugin such as Normalize, the results seem fine, so I guess I will stick with that setting.
Glad you found something that works for you!
AJHBEATS |
Audio Suite dither | behan | Pro Tools 11 | 2 | 02-08-2014 10:00 AM |
Default audio suite dither | budster | Pro Tools TDM Systems (Mac) | 4 | 09-18-2008 09:06 AM |
Dither and Pow'r Not In Audio Suite Dropdown | WilberForce | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 04-30-2007 09:10 AM |
AUDIO SUITE DITHER HELP | Risto | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 9 | 09-28-2005 03:00 AM |
Why NO Dither in Audio Suite??? | nehemiahmh | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 04-28-2005 09:40 AM |
