Syncing ProTools with Roland VS840
Hello All,
I'm nearing a purchase of the DIGI 001 (just awaiting XP support) and currently have a Roland VS840 workstation. My intention would be to migrate my existing material from my VS840 to the ProTools LE Software. I'm assuming that this may be possible track by track using the SPDIF connections between them. Is there a way to sync these up so they start playing (VS840)/recording (PTLE) at the same time? (ie: so all the tracks for an individual song are lined up correctly) Am I completly crazy trying to do this or is this possible? Thanks for any comments/suggestions you may have. ostrich99
iMac 27" - i7 - 2.8Ghz - 16GB - DIGI 003 Rack Factory - Glyph |
Re: Syncing ProTools with Roland VS840
Yeah, someone please answer this. I am in the same boat as ostrich99, where I already have the vs840 and will be getting a digi 001 really soon. Thanks a lot!
accameron,
After searching the DUC a little more throughly, I found this thread with may point us in the right direction. Link to Thread (I'm having trouble getting the above link to work right. You might have to cut and paste it into your browser and make sure there isn't a space before the t=006153) It doesn't have a step by step, but it might help us out. ostrich99
I won't repeat all the Digidesign info (it's accurate), but I will confirm that it's very possible to sync any hard disk recorder to a Digi 001 as long as the hard disk recorder transmits MIDI Time Code (MTC). If it has a S/PDIF or lightpipe digital outputs, you can even transfer tracks from the HDR into PT for editing, and then fly them back...
I do this every day with a pair of Yamaha AW4416's and a Digi 001 running on a PC.
Phil O'Keefe PT 2023.6 Ultimate (Perpetual) | Avid Carbon | M1 Max Mac Studio; 32 GB RAM / 1 TB SSD, macOS 13.4.1 Ventura. PT 2023.6 Studio (Perpetual) | M1 MacBook Air; 16 GB RAM / 1 TB SSD, macOS 13.4.1 Ventura. |
Here's a post from a Digi rep in responce to this same question asked by someone else:
Advice about syncing roland-Tb303 | protuser | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 09-13-2008 09:31 PM |
Syncing with Roland VS-880EX | Vic D | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 9 | 05-28-2003 06:35 PM |
Transfering from a Roland vs840 to digi001 using spdif optical | eldwin | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 11-08-2002 11:48 PM |
Syncing Roland vs1680 too Protools 5.1 PC | brainstormsounds | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 10-09-2002 07:15 PM |
Syncing to Roland VS-1680 | RenaissanceKid | MIDI | 12 | 08-15-2001 03:38 PM |
