Latency?
I am currently in the market for a Digi 001 (doing all the research that I can, and waiting for the windows xp upgrade), and I have come upon a concern about the system. People talk about latency here and there on this forum. Does the Digi 001 always have a little latency when recording on a good PC, or only when there are some plug-ins running? That would suck if there was any latency at all. Thanks a bunch.
Re: Latency?
Bad news bud!All host based DAW's have latency,be it emagic,cubase,PT or what have you,due to the fact that all calculations run through a single processor.
The digi 001 offers some nice ways of combatting it though,like "low latency recording" and the like.Once you get your head around it, it works fine.If yo want a system with less latency,grab a bank loan and buy TDM.But even there they have some serious latency issues a user has to deal with.
If you're gonna laugh about it later, you may as well laugh about it now |
Re: Latency?
LE has never given us latency problems that couldn't be helped with low latency monitoring. When you are recording, you don't have as many, if any plugins going, so it isn't a big problem.
Re: Latency?
Yeah I totally agree...I was really worried about it, but it's not a problem at all. If you don't want to use any effects on the track you're recording (as you track it) you can put it in low latency mode. Which is virtually none.
I always like to add a bit of reverb while recording vocals,(personally I think it improves the performance) so I use aux sends which work fine. Low Latency doesn't work with sends and plugins, if the track is rec enabled. There are diff buffer settins, 128, 256, 512, and 1024. The 128 setting is close enough to real time. As you mix you set the buffer higher and get more plugins. I know some of this is redundant, but if you don't have protools yet, I assume you don't know how the workarounds really work. |
Automation latency when using plugins that have long latency | pyrodave | Pro Tools 11 | 2 | 01-27-2014 11:22 AM |
omni/native latency vs mbox pro latency | chrisdee | Pro Tools HDX & HD Native Systems (Win) | 34 | 03-30-2012 07:24 AM |
Latency Issues - changing latency has no effect | Kippa-Dee | Pro Tools M-Powered (Win) | 1 | 07-15-2010 08:39 PM |
Piano VI's- Latency Latency!! | MARVINBASS | Virtual Instruments | 5 | 04-27-2006 01:09 AM |
Unity DS-1 and Latency... Anyone else feel the latency makes the Plugin unusable? | Mt.Everest | Pro Tools TDM Systems (Mac) | 7 | 08-26-2001 04:53 PM |
