Old 11-20-2022, 04:37 PM
chriskyang chriskyang is offline
Default Volume
Hello;
I am trying to play instrumental tools & Pro Tools. Yet, the volume on the instrumental track, will, not: work.
Any help would be grateful.
Thank you.
I am using Beats Solo, with: wired, connection.
Old 11-20-2022, 05:19 PM
Default Re: Volume
Welcome to DUC.
Lots of the info expected is missing: Mac or Window? What is the playback engine set to? Exact version and release date of Pro Tools? Have a read of "help us help you" up the top of every DUC web page to see the kind of info that is expected.
No idea what you mean by "instrument tools" What virtual instrument (VI) plugin are you trying to use? That VI plugin needs to be inserted on the instrument track.
Unclear exactly what you mean by "volume". You are adjusting what exactly/where exactly? The instrument track fader? MIDI volume automation, Volume automation?
Does anything work? Can you play back a prerecorded commercial audio file? That you drag and drop into the Pro Tools edit window? If not get that working first.
Especially while you are learning do stuff try out new things as simple as possible. e.g. here when working with the VI start with a new session with one (instrument) track and get that woking OK. No routing, no sends, no other plugins besides the one VI.
Best as well to find some tutorials on YouTube or similar about getting started with virtual instruments. Get basic audio working first.
Old 11-20-2022, 05:38 PM
Default Re: Volume
Thank you.
I am currently using; a: 2015 Mac Pro. Not quite sure, what the playback engine is, or even is: at.
The version I am using is the 30-day Trial.
Yet, to read the "help us help you". Will: do, partially.
https://www.youtube.com/watch?v=HYxtbJPhEC4 :
Followed the guidelines to this. Earlier.
The "click" does not even work (as in volume - cannot hear it going / playing)
Thank you, again for: the help.
Old 11-21-2022, 04:59 AM
Ben Jenssen's Avatar
Default Re: Volume
Chris; you should start by checking out videos on "getting started with Pro Tools", "How to set up Pro Tools", "using a Pro Tools interface" and similar.
Pro Tools is not so easy to get started with, very much not so. Have you considered other DAWs, like Abelton Live and such? Seriously I would suggest Garageband since you're on mac, it's free, and easy.
Old 11-22-2022, 09:30 AM
Default Re: Volume
Thanks to all! Fixed the problem!
Here's a link to my SoundCloud: chriskyang
Playback volume hotter than recording volume..help! firmflange Pro Tools 12 4 02-07-2020 04:40 PM
Mbox Pro 3: master volume knob won't affect volume at all Veledron FireWire & USB Audio Interfaces (Win) 2 02-06-2018 06:20 AM
Monitoring volume in Pro Tools doesn't match computer volume Drakken Pro Tools M-Powered (Win) 0 01-17-2012 02:56 PM
Converting Volume Automation to Clip Gain = Higher Volume! EricWillhelm Pro Tools 10 8 11-01-2011 11:12 AM
Special paste midi volume to audio volume? Richard Fairbanks Pro Tools TDM Systems (Mac) 0 07-30-2003 09:52 AM
