Old 01-23-2007, 11:25 AM
audiopronorth audiopronorth is offline
Default 7.3.1 LE randomly deleting regions when saving
When saving a session copy from 7.3.1 LE down to ver. 6.9 (and lower) I have lost regions from the time line in the edit window. Basically I delivered a session to a mix that was missing regions. These regions exist in the pt 7.3.1 session file and do not exist in the copy that I made for the mix. PT randomly deleted regions and in some cases where I had a cross-fade deleted the first half and the cross-fade but left the second half of the region. As a test I saved a 7.3.1 session copy to 7.3.1 and did not lose any regions. When I repeated the save session copy down to ver 6 again the same regions where removed in the ver 6 session. It was my understanding that this was a known bug in 7.3 and had been fixed in 7.3.1. Obviously it is still a problem. I'm looking for a fix as everywhere I mix is still running Ver 6.9 or lower.
Old 01-23-2007, 12:22 PM
lemix's Avatar
lemix lemix is offline
Default Re: 7.3.1 LE randomly deleting regions when saving
If you had those regions "grouped"..this is a normal behavior.
There is a warning pop-up with all dropped elements listed, when saving copy in any version below 7.
in order to have all regions copied over, you'll need to 'ungroup" them first.
good luck,
cheers,
Andrew
W7 pro 64_i7 3930K_16GB_ Nuendo 6.5.4-7.1.3 / PT 12.4 ------Mac Mini OSX Lion_PT 10.xx
Allen&Heath GS R-24M_ full rack of vintage analog boxes _UAD2_Nugen_iZotope_Melda_Waves_Plugin Alliance_DMG and more
2.0 and 5.1 monitoring
Old 01-23-2007, 12:58 PM
Thanks for the reply. Unfortunately that is not the problem. The regions were not grouped.They were on a mono track in both instances and had never been in a region group.
Old 02-04-2007, 06:54 PM
kustota kustota is offline
audiopronorth, do you lose regions - as i do - when saving even to native 7.3.1 format?
Old 02-04-2007, 08:03 PM
No.
I bought Pt 7.3.1 and used it for 1 session. When I saved that session down to 5.x-6.9 and found the problem, I uninstalled it right away and have not used it since.
Old 02-05-2007, 12:47 AM
tommy2fingers tommy2fingers is offline
I'm running 7.3.1 and I lost a region and had to manually relink it myself.
Makes me worried that you can lose a chunk of your session and then have to paste the thing back to gether yourself...
I thought this problem had been fixed by the 7.3.1 download?
Old 02-05-2007, 01:01 AM
sky88dd sky88dd is offline
Hi, it happened to me a few times too while I was saving a copy of a session to a lower version(or save a copy in general). I lost a whole track of drums.
I don't know if it works for you but what I did was consolidate that whole drum track and then save session copy as.
Then I checked the copy and the drum tracks were there.
Hope it helps.
PPC G5 Dual 2.0, 8.5G Ram
PT 8 cs2 OSX 10.5.8
MBP Core 2 Duo 2.16, 2G Ram
PT 8 cs2 OSX 10.5.8
Mbox 2 Pro, Mini, Micro
Old 02-05-2007, 01:14 AM
Hope it helps.
I didn't save a copy, or save it to a lower version, I just saved the session.
Regions were missing when I re-opened the same session later.
I haven't even started saving copies of sessions with lots of edits...can't wait.
7.3.1 is just great, isn't it?
I thought they'd fixed this probelm they had with 7.3?
Old 02-05-2007, 02:20 PM
Hi, I was actually referring to the 1st post regarding the saving to a lower format and losing regions.
But as far as saving a session and losing regions, have you checked disk allocation?
PT 8 cs2 OSX 10.5.8
PT 8 cs2 OSX 10.5.8
Old 02-05-2007, 08:16 PM
Yeah as a test i did consolidate the missing regions and resave and that did "fix" the immediate issue. However I have stopped using 7.3.1 and unfortunately don't plan on using it again for quite a while as i don't have time to beta test software for digidesign. I like to help and all that, but this is supposed to be professional software that I use everyday for my work, not an open source project.
10.3.7 randomly deleting files method1 Pro Tools 10 7 11-28-2013 09:10 AM
Regions randomly nudging on their own accord!! cabletwitcher macOS 5 12-13-2012 02:16 PM
Randomly Saving Files To The Wrong Drive (C) rocknrollchef 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 04-29-2008 06:52 AM
Losing tracks/regions randomly... aarrrgh Blistered Sky Pro Tools M-Powered (Win) 3 07-10-2007 05:41 PM
Saving Space: Deleting Audio files? pribb1 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 05-31-2004 07:10 PM
