  #21
Old 10-16-2012, 05:02 AM
soundarchitect soundarchitect is offline
Default Re: 10.2 Glide Automation Behaviour
Update: Glide automation is still buggy. The way discribed by CJ is working for me. But the way the manual describes it is only working when automation is SUSPENDED.
So putting your selection tool anywhere in the edit window, change parameter and glide to it only works when the automation is disabled, wich means that PT's before writing the automation actually looks at where the current automation value is.
This seems not right to me...?
Could anyone confirm?
Cheers
  #22
Old 01-09-2013, 02:27 PM
masterboyle masterboyle is offline
I'm having a problem with glide in 10.3.3 on two HD Native Systems.
Let's say I want to glide pan automation, this is what I do:
Make a selection on mono track, first "write to all enabled" pan hard left across the entire clip just to establish a default pan position for the clip. Then with the same selection I move the panner hard right and hit "glide to all enabled." On PT 9 this would work, now it simply writes the "end of clip" value to the entire clip, the same way that "write to all enabled" would behave.
Is this user error? What am I doing wrong?
Brian
  #23
Old 01-10-2013, 04:44 AM
joachim's Avatar
joachim joachim is offline
Brian
I am not an expert, but I believe, that the problem is the "same" selection", because at the start of the "same" selection there is the parameter "hard right" and at the end of the "same" selection there is also "hard right" - nothing to glide.
As I understand it, if you want to make a glide from left to right, taking place from the start of your desired selection to somewhere withinin :
make a selection more than your desired selection, automate "hard left"
make your desired selection, automate "hard right"
make a selection from just outside your desired selection ("hard left") to somewhere inside your desired selection ("hard right") and glide-to-all-enabled.
HTML code is On
Glide Automation bug in PT 10.3.4 mgoorevich Pro Tools 10 19 03-17-2013 09:09 AM
Glide Automation still not working? soundarchitect macOS 1 01-08-2013 11:17 AM
10.2 Glide Automation Behaviour moofie macOS 0 06-05-2012 03:24 PM
glide automation still works? tomcat Pro Tools TDM Systems (Mac) 5 01-27-2008 05:13 PM
D-Command, Preview, Glide automation Redhouse_Janke ICON & C|24 0 12-13-2007 07:04 AM
