Old 04-15-2010, 03:57 AM
Default Stereo EQ3 doesn´t split to mono
I´ve come across an issue a fellow editor told me about.
When you split a stereo-track that contains a stereo EQ3 to mono all the EQ automation is lost.
With multi-mono it works fine but not with the new stereo EQ3.
It´s also not possible to manually copy-special/paste the automation from the stereo EQ3 to a mono EQ3 because PT treats them like 2 completely different plugs.
This is not good.
Better stick to multi-mono if you want to keep your options.
HTML code is On
How to split a stereo bus into 2 mono busses zenstone Tips & Tricks 3 02-16-2011 05:05 PM
Split stereo into to mono Nesp Pro Tools M-Powered (Win) 3 03-04-2010 12:03 PM
BUG (?): Match clip doesn´t work on split mono Frank Kruse Post - Surround - Video 5 12-17-2008 06:34 AM
2 mono split - to 1 stereo file rinky Pro Tools TDM Systems (Mac) 3 06-28-2006 04:18 PM
What do i import a "dual mono" audio file as??? mono or split stereo? peter parker 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 07-17-2002 04:02 AM
