TC System 6000 integration with PTHD
Hi Guys and Gals,
I'm thinking about buying a TC System 6000 to 'up' the level of reverbs I have available while mixing 'in-the-box'. I know ReVibe is coming out, Altiverb, etc., etc... but I really love the sound of the 6000. Does anybody know what the deal is with the network integration with a Mac? I don't know much about the hardware side of things, and I'm curious if I need to buy the CPU unit in order to use the Icon Remote, and if so, can I get away with using the Mac Icon software, and tweaking and saving presets right from the computer (and thus, not have to buy the CPU box)? Can you save your setups (in whatever file format) into your session file folder for backups? I'd love to hear from anyone who has this setup working! I'd likely buy the digital-only version, and skip out on buying any analoge I/O at first... Anyhow, Cheers for now! |
Re: TC System 6000 integration with PTHD
it is my understanding that you have to have at least one cpu unit regardless of whether you run the hardware icon or software. I believe you can drive multiple 6000s from one cpu
Doug |
Doug is correct in that you need 1 CPU unit. You can use the icon software instead of the Icon and save the files as you suggested. I've got a digital only 6000 hooked up to my HD system as 4 stereo or 8 mono digital inserts and it works great. Highly recommended!
Jamie |
Thanks for the info guys!
So... You can't just buy the Mainframe only (about $6600 at Sweetwater) unless you already have an Icon/CPU. You have to buy the M6000 bundle for about $8300, and you figure that comes with the CPU and the Icon remote? Is there any must-have software that I'll need that doesn't come with the base unit? I probably won't need any of the surround pitch and time expansion software, or the MD6 mastering stuff. Does it come with the MD3? Cheers! |
It doesn't come with the MD3, nor any other package except the reverbs. It is definitely a great tool. BTW: you don't really need the icon, but if you can afford one, it's worth it for the client appeal alone. Also, it's nice to be able to make small changes really quickly.
Be aware also that the icon software, unless they recently upgraded things, runs on a pc-only. |
I'm on 10.3.2 at the moment. |
bought a TC6000 mainframe + ADA 24/96 (2 cards) and the SW ICON (no extra cpu)... I'm not using the analog, going AES with PTHD... price was good thru Pro Audio Design
They've just released the Mac OSX Icon software, so for me, that's ideal! |
You do not need the CPU. I am running a System 6000 mainframe with only the remote ICON software. AES/EBU into the 192. The software works flawlessly. The System 6000 connects via Eithernet, just plugged it into my hub. My setup is PT HD3/192 on Mac and the remote software runs on a Windows XP machine. With the Mac OSX ICON software available I might run it the Mac, but having it on a separate screen is nice.
Look/ask for the following (note, eventhough it says Windows software, it's the ICON software license for Mac/PC): System 6000 Mainframe with Digital I/O and Windows control software 902-1000 + 905 006030 System 6000 mainframe with 8 channel DIG I/O and Windows control software (No TC ICON remote) This package retails at $7,295.00. The standard mainframe lists at $6395 and the ICON software is $1,000 so the bundle saves you $100. These are prices from a year ago, don't know if they've changed because of the weak US$. Busch. |
If stereo is all you need then the TC4000 has the same reverbs under $2500. Nice.
sm
macmandigital.com |
FS: TC electronic System 6000 MKII | audiocontrol | Buy & Sell | 8 | 07-05-2013 10:33 AM |
Unwrap PT <-> tc System 6000 | thierryd | Post - Surround - Video | 3 | 03-05-2007 11:53 PM |
Who have tried the TC system 6000 TDM plugins? | kinghand | Pro Tools TDM Systems (Mac) | 9 | 09-13-2005 09:38 AM |
TC System 6000 | Ulfius | Pro Tools TDM Systems (Mac) | 10 | 11-13-2002 05:57 AM |
TC System 6000 and PT? | PTstress | Pro Tools TDM Systems (Mac) | 2 | 08-17-2001 08:11 PM |
