How do I make Logic load DAE and native drivers??
I just installed a Mix Plus system (after using a regular 24 system) and now I can't launch Logic with both the DAE/TDM and "mac AV" (native) drivers selected in Logic Audio. I get an error code -6011. Other native drivers (ASIO, Direct I/O) just won't load period when DAE driver is loaded. They all work by themselves though.
Can anyone offer some advice here? It worked with the old hardware... TIA |
Re: How do I make Logic load DAE and native drivers??
You have to pull out the Digi extension (sorry, I can't remember the name, been using OSX too long now) that allows Sound Manager to be routed out the Digi hardware. The problem is that Logic is competing with this driver when you try to enable Mac A/V.
hope this helps. -bob |
Pro Tools HD drivers don't load correctly everytime | rcd | Pro Tools TDM Systems (Win) | 0 | 06-16-2011 11:46 AM |
Mbox 2 Pro Drivers dont load at boot up. | sheezy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 02-03-2010 03:15 PM |
PT 8 install doesn't load 002 drivers | DanDeurloo | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 14 | 02-11-2009 12:23 PM |
Can you make protools load faster? | jack2006 | Pro Tools M-Powered (Win) | 4 | 06-22-2006 07:27 AM |
PT 5.3.1 will not load drivers - HELP! | lexluth | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 12 | 07-08-2003 09:05 AM |
