(Apologies to the high end purists used to big budgets for this question. I know this is not how things should be done but ...)
I've had a stereo session thrown at me that I need to convert to a rough 5.1 mix. (This is a quick job with no budget, and there's no immediate need for a perfect theatrical mix, LFE etc.) The session has separate stereo aux busses for dialogue, spot FX, atmos and music and for reverbs. I am not planning on doing much more than pushing a little of the reverbs into the surround channels and twiddling with the panning a couple of spot FX when appropriate. Am I right in thinking the simplest thing to do is just change the outputs of all the aux tracks from stereo to 5.1 and pan accordingly?
PT2020.5.0 / HDN / HD Omni / MC Control / Intensity Pro / Catalina / 3.7 Quad core Intel Xeon ES (trashcan) MacPro / 12GB RAM Over 20yrs experience in TV. Currently mainly indie features. |
In short yes.
What usually I do when I received that kind of element is: - Dialog - Pan to center (99% of the time) - Spot FX - If it's sync to picture, panned to center - Atmos - If it's a real stereo recording I'll pan up to 50:50 (90% of the time to front only) - Music - Pan 90:90 and pull to surround a bit - Reverb - If it's music verb, I'll make two copies (can use multiple aux) and spread one track to front and the other delayed to surround. But then again it's a creative process. If it's sound good then It is ...
Satrio Budiono FourMix JFS Mac Mini (2018) 3.2GHz 6-Core i7, 32GB RAM, OSX 10.15.7, PT Ultimate 2021.7, Sonnet TB2 III-D, Avid HDX 2, Sync X, MTRX Studio, BSS BluDan, JBL Intonato, JBL 708P & 705P |
Thanks Bokir. Pretty much exactly what I was doing, but good to know I'm not missing something important.
Use spanner to pan and unwrap to make your music and atmos into 5.1
cheers Mike Aiton BSc (hons) Dubbing Mixer/Sound Designer BAFTA member IPS member former Post Production Expert at www.pro-tools-expert.com ------------------------------------------------------------------- www.mikerophonics.com |
+1 for Spanner, AAX DSP and with a Rotate feature now
Routing to give a stereo group a stereo plugin on the VENUE plus AES EBU uses | somtech | VENUE Live Sound Systems | 5 | 05-19-2012 06:43 AM |
Routing Monitor Stereo through Plugins ... | Brad Harris | VENUE Live Sound Systems | 1 | 04-27-2010 12:56 PM |
Stereo Aux not Routing to Master | blizzard | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 09-15-2009 07:20 AM |
Mixdown routing for 5.1 AND Stereo in 1 pass | Peter Groom | Pro Tools TDM Systems (Mac) | 2 | 08-11-2009 12:15 AM |
TL Space True Stereo Routing Issue - HELP | innenhofstudios | Pro Tools TDM Systems (Mac) | 2 | 02-18-2009 08:27 AM |
