Old 05-11-2013, 07:29 AM
shumo shumo is offline
Default Crash when consolidate clip
This doesn't happen all the time, but PT will crash when I consolidate a clip. It started when I updated to 10.3.4 and also does it in 10.3.5. Never ever did it in PT 9 or first version of 10. Been doing this for 5 years.
I started saving just before I consolidate and that helped some, but will still do it randomly.
Also after the crash PT doesn't remember the file in recent files.
Was wondering if anyone else has had this happen, and if so did you find a fix?
I do radio promos and the short ones(1 & 2 min) are not so bad, but to lose all the editing work you did on the 15 min program is a nightmare.
Any help is appreciated.
Old 05-11-2013, 07:45 AM
Stig Eliassen's Avatar
Default Re: Crash when consolidate clip
I haven't seen this behavior on any versions of PT, and I'm now on 10.3.5.
Did you un-install previous PT versions before installing 10.3.4/10.3.5? That is recommended by Avid.
Have you tried to trash PT preferences? Repaired disk permissions with Disk Utility? I always do that after installing/updating, and restart the Mac.
Below is a link to general troubleshooting tips from Avid.
http://duc.avid.com/showthread.php?t=54888
Old 05-11-2013, 10:14 AM
Computer and OS? PT setup? Need more info. But all the same I've not had any crashes consolidating clips.
Jack
QAPLA!
Old 05-13-2013, 09:55 AM
Exclamation Re: Crash when consolidate clip
The currently open session is not added to the top of the recent files list until you close the session.
Consolidate Clip + Crossfade = Distortion in PT11 soundhillaudio Pro Tools 11 0 02-27-2014 01:51 PM
Clip Gain and Consolidate Track Bo Walker Pro Tools 10 4 09-03-2012 02:01 PM
Consolidate Function Causes Crash - Please Help jmstudio 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 07-27-2012 06:45 AM
Consolidate causes Address Error Crash spelbring Pro Tools TDM Systems (Mac) 2 08-26-2003 11:02 AM
Consolidate crash @48khz spelbring Pro Tools TDM Systems (Mac) 3 07-26-2002 06:59 AM
