Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools 2020
Old 05-17-2021, 09:08 AM
Gwenkamol Gwenkamol is offline
Default Problem with the Video Engine
Hello everyone.
My Video Engine is not working, and I can't find out why.
I'm using Pro Tools 2020.12, I tried uninstalling and reinstalling Pro Tools, the Video Engine, the Codecs...
I have 2 error messages ; when I try to import video, Pro Tools says "Unable to link to file X due to either a missing CODEC or the file may be unsupported."
The second error message is "The video engine had an unrecoverable error and will now reinitialize."
I tried importing video with different CODECS, DNxHD and ProRes, as well as different types of video files (.mov, .avi and .mxf).
I don't know what to do, and I have a school project to finish in 2 weeks which needs the Video Engine.
Thank you in advance for any help !
Old 05-17-2021, 10:06 AM
its2loud its2loud is offline
Default Re: Problem with the Video Engine
Originally Posted by Gwenkamol View Post
Hello everyone.
Try removing any old videos you may have imported from the session. If they’re not on the timeline, remove them from the sessions clip list. Once you e removed all the video files, save and close the session. Restart Pro Tools and import your most recent video file. I recommend staying with the DNXHD codec but make sure you’ve installed the Avid Codecs on your system.
You’ll find the Avid Codecs LE package here
https://avid.secure.force.com/pkb/ar...nload/en423319
Also, you don’t state what your system specs are so it’s a little hard to determine if there are any system incompatibilities.
Old 05-17-2021, 10:29 AM
I tried removing old videos, even started a fresh session, it didn't change anything. I did install the Codecs, so that's good...
Sorry I forgot about the system specs : I'm on windows 10 Home, and i have an Intel core i7 6700K, a NVIDIA GTX1070, 8Go of RAM.
I know the RAM seems pretty low, but the video used to work before on my PC...
I completely reset my PC about 2 months ago, and I think it's since then that it doesn't work anymore. Maybe some driver or something is missing since I reset the computer ?
Thanks for your answer by the way, it's very appreciated !
Old 05-23-2021, 04:12 PM
coaxmw coaxmw is offline
Is your video in a folder with any illegal characters or unusual characters. I've had that error when there is a / or %@ type symbols in any of the folders that contain the file. Can you import a video from another project or your desktop still?
Old 05-25-2021, 10:53 AM
Nope, no weird characters in the folder's name or anything.
I can't import video at all in Pro Tools.
I tried to import video in Ableton Live as well, and it didn't work. I think it's related to a software problem on my PC, but I don't know why. Is it something missing maybe ?
Old 09-02-2022, 12:41 PM
jivanroopa jivanroopa is offline
hi bro dd you find a solution ???
even i am facing the same thing unable to import manually nor shortcut key working
using Pt 12.5.0
this my system config
Model : Dell Precision M4800
Serial Number : 618****
Chassis : Dell Laptop
Mainboard : Dell 0T3YTY
Serial Number : /6183XZ1/CN1************
BIOS : Dell A06 01/02/2014
Intel Management Engine (ME) : 9.0.21.1462
System Memory
Total Memory : 8GB SO-DIMM DDR3
Processors
Processor : Intel(R) Core(TM) i7-4800MQ CPU @ 2.70GHz (4C 8T 3.3GHz, 3.3GHz/3.7GHz IMC, 4x 256kB L2, 6MB L3)
Socket/Slot : FC BGA1023
Chipset
Memory Controller : Dell Core4 (Haswell) DRAM Controller 100MHz, 8GB SO-DIMM DDR3 1.6GHz 64-bit, Integrated Graphics
Memory Module(s)
Memory Module : Samsung M471B1G73DB0-YK0 8GB SO-DIMM DDR3 2Rx8 PC3-12800SO DDR3-1600 (11-11-11-29 5-40-13-6)
Video System
Monitor/Panel : Dell Computer DELL P2419H
(1920x1080, 24.0")
Monitor/Panel : AU Optronics Generic PnP Monitor (1920x1080, F2J5X€B156HW2, 15.5")
Video Adapter : Intel(R) HD Graphics 4600 (160S 20C SM5.5 1.3GHz, 512kB L2, 2GB DDR3 1.6GHz 64-bit, Integrated Graphics)
Graphics Processor
OpenCL : NVIDIA Quadro K1100M (384S 2C SM1.2 705MHz, 2GB 2.8GHz/2.8GHz)
OpenCL : Intel(R) HD Graphics 4600 (160S 20C SM1.2 1.3GHz, 256kB L2, 1.6GB DDR3 1.6GHz 64-bit, Integrated Graphics)
D3D 11 : NVIDIA Quadro K1100M (384S 2C SM11.5 705MHz, 2GB 2.8GHz/2.8GHz)
OpenGL : NVIDIA Corporation Quadro K1100M/PCIe/SSE2 (2GB)
Storage Devices
Disk : HGST APPLE HDD HTS727575A9E362 (750.2GB, SATA300, 2.5", 7200rpm, 16MB Cache)
Disk : Samsung SSD 850 EVO mSATA 250GB (250GB, SATA600, SSD, SED)
Optical : HL-DT-ST DVD+/-RW GU90N (SATA150, DVD+-RW, CD-RW)
Logical Storage Devices
New Volume (D:) : 342GB (NTFS, 4kB) @ HGST APPLE HDD HTS727575A9E362 (750.2GB, SATA300, 2.5", 7200rpm, 16MB Cache)
Hard Disk (C:) : 232GB (NTFS, 4kB) @ Samsung SSD 850 EVO mSATA 250GB (250GB, SATA600, SSD, SED)
Hard Disk : 508MB (NTFS, 4kB) @ Samsung SSD 850 EVO mSATA 250GB (250GB, SATA600, SSD, SED)
New Volume (E:) : 357GB (NTFS, 4kB) @ HGST APPLE HDD HTS727575A9E362 (750.2GB, SATA300, 2.5", 7200rpm, 16MB Cache)
Hard Disk : 96MB (FAT32, 1kB) @ Samsung SSD 850 EVO mSATA 250GB (250GB, SATA600, SSD, SED)
Optical Drive (F:) : N/A @ HL-DT-ST DVD+/-RW GU90N (SATA150, DVD+-RW, CD-RW)
Storage System
Storage Pool : Primordial (931.52GB)
Peripherals
LPC Hub Controller : Dell ICH80 (Lynx Point) LPC Controller
Audio Device : Dell ICH80 (Lynx Point) HD Audio Controller
Audio Codec : Realtek Semi 0292
Parallel Port(s) : 1
Disk Controller : Dell ICH80 (Lynx Point) 6-Port SATA AHCI Controller
Disk Controller : Dell SD/MMC Card Reader Controller
USB Controller : Dell ICH80 (Lynx Point) USB3 xHCI Host Controller
USB Controller : Dell ICH80 (Lynx Point) USB2 Enhanced Host Controller #2
USB Controller : Dell ICH80 (Lynx Point) USB2 Enhanced Host Controller #1
SMBus/i2c Controller : Intel ICH SMBus
Printers and Faxes
Printer : Send to Microsoft OneNote 15 Driver (1200x1200, Colour)
Printer : Microsoft Software Printer Driver (300x300, Colour)
Printer : Microsoft Print To PDF (600x600, Colour)
Printer : AnyDesk v4 Printer Driver (600x600, Colour)
Biometrics
Voice : Analog NUI Voice Virtual Sensor (Voice)
Network Services
Network Adapter : Bluetooth Device (Personal Area Network) (Ethernet)
Network Adapter : Intel(R) Ethernet Connection I217-LM (Ethernet)
Wireless Adapter : Dell Wireless 1550 802.11ac (Wifi4 (802.11n/HT), AES-CCMP, 111Mbps / 78Mbps)
Battery : LGC-LGC3.0 DELL 49VTP 56.16Wh/4.51Ah
Operating System
Windows System : Microsoft Windows 10 Professional 10.0.19043
Problem enabling video engine 2019.6 Lydbildet Windows 12 04-02-2020 10:24 AM
Video engine problem lesbrunn Pro Tools 2019 7 02-21-2020 05:26 AM
Video Engine Launch Problem [email protected] Pro Tools 11 0 04-08-2016 06:21 PM
Video Engine Problem PT Hd 11 [RESOLVED] [email protected] Pro Tools 11 2 09-22-2015 02:56 AM
PT10.0.1 video engine Mojo SDI problem Francis Bernier Windows 0 02-03-2012 02:16 PM
