Old 07-05-2022, 04:58 PM
Samba Samba is offline
Default PT 2022.6 on Mac Big Sur 11.6
I've just updated to PT 2022.6 on Mac Big Sur 11.6.
Since the update, most of the midi functions have ceased to work.
The compatibility grid says they are compatible.
Anyone know if it's a bad combo?
I had it working fine when I was using PT 2021 on Mac Big Sur 11.6.
Old 07-06-2022, 09:10 AM
JJ Lang JJ Lang is offline
Default Re: PT 2022.6 on Mac Big Sur 11.6
Re-install you midi apps and they should work. I had to do this.
Old 07-06-2022, 09:51 AM
Ben Jenssen's Avatar
Welcome to the forum.
I understand you're trying to be helpful, but you should understand that this community have quite successfully managed to maintain a good level of precise and to-the-point exchange of information, unlike many other forums that suffer from a breakdown of factuality and general common curtesy.
The OP is asking about midi functions in protools after a PT update, not about other midi apps. I think perhaps you were a bit careless in replying without thinking it thru and making shure you understood the question.
Old 07-08-2022, 06:02 PM
Does anyone know if these should be operating together?
Old 07-08-2022, 07:04 PM
rinky rinky is offline
I'm on Big Sur, running PT Ultimate 2022.6. Aside from the usual intermittent crashes, it's working fine here.
PT Ultimate 2024.3
PT HDX
MacPro 7,1 (Intel)
16 Core
96 GB ram
macOS Ventura 13.4
Somehow, musicians are now technicians!
Old 07-09-2022, 10:38 AM
dominicperry dominicperry is offline
Plenty of people reporting midi problems with 2022.6 on this forum.
Just look at the list of recent threads or do a search for "midi".
Some people are reverting to 2022.5
Dominic
MacBookPro M1Max 16" 10/32 64GB 2TB, Ventura 13.6.6, Pro Tools 2023.12.1, Carbon.
Old 07-09-2022, 11:16 AM
Indeed. Having issues with midi quantize.
Thinking on reverting to 2022.5 since I am currently in heavy midi world.
PT Ultimate 2024.3
PT HDX
MacPro 7,1 (Intel)
16 Core
96 GB ram
macOS Ventura 13.4
Old 07-10-2022, 03:14 PM
I don't get it - Why is Avid claiming they are compatible? Clearly they aren't if we have to roll back
Old 07-10-2022, 05:05 PM
Just upgraded to Monterey. But 2022.6 is compatible with Mojave. It's just that this release has some annoying quantize bugs with midi.
PT Ultimate 2024.3
PT HDX
MacPro 7,1 (Intel)
16 Core
96 GB ram
macOS Ventura 13.4
Old 07-10-2022, 07:18 PM
Compatible simply means that the application is compliant with the platform (operating system). It does not mean that there are no coding bugs. This MIDI quantize bug is a "bug," not a compatibility issue.
Obsidian Dragon
Mac Studio M1Max - 64GB
Pro Tools 2022.6 with Avid Control 2022.4 stargazer Pro Tools 2 07-01-2022 07:32 AM
Pt 2022.5? Raggi Pro Tools 47 06-16-2022 03:49 PM
Crash moving tracks to new Routing Folder in PT 2022.4 [FIXED 2022.5] Dizzi45Z Pro Tools 43 05-29-2022 03:59 AM
