Old 02-08-2011, 05:51 PM
tobias bluth tobias bluth is offline
Default Waves plugins causing phasing
hello,if i insert a waves c6,c4,L3 multi-or utramaximizerLL on a parallel track,i got some serious phasing issues,troubleshot with the kind people of avid support, did a fresh install of machine and protoolsno change.before i go trough the same hassle with waves support,i want to know if anyone got a solution.i know this was asked before by others but as far as i know not answered yet.thank you
Old 02-08-2011, 06:50 PM
danander11 danander11 is offline
Default Re: Waves plugins causing phasing
Do you have delay compensation enabled? and if so, what is the total delay on the parallel track? if it is exceeding the ADC in PT9 you are going to have issiues. As I recall, L3-16 has almost 5000 samples of delay.. All of the plugs you mentioned have a fair bit if my memory serves.
Try copying all of the plugs to the original track and bypass them all (not make inactive).
Here I am,
after time not long...
and thankful for the break,
What I found when I got there,
was that I couldn't stay away!
Hobo Shave!
Old 02-09-2011, 02:26 AM
i am just talking about the LL(low latency)versions of these limiters they have about 64 samples of delay same as the c6 and c4.delay compensation on or off give me the same results.lots of the other waves stuff i one share a latency of that value without giving me that headache
Waves C6 causing phasing even in bypass crizdee Pro Tools TDM Systems (Mac) 30 02-09-2011 05:40 PM
Updated Waves Plugins causing mouse/002 issues? Longshanks 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 15 06-10-2010 04:18 AM
ADC causing phasing on record stems Brandonx1 Post - Surround - Video 0 06-22-2009 01:42 PM
Inserting Plugins causes phasing on the whole audio buss fradenigris Pro Tools TDM Systems (Mac) 0 06-28-2007 02:29 AM
Quantize: causing double midi notes; phasing??? gollywillickers 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 08-23-2005 10:39 AM
