Gain plugin and RMS calculation
Why does AudioSuite's "Gain" plugin produce an analysis that is so low when compared to that of other plugins and other software? Is it due to a difference in internal RMS parameters such as gating? If so what parameters does Gain use for its analysis?
Thank you for any help you can offer for what I'm sure is a very basic question. I have a project which has an RMS stipulation for the output, and I'm trying to understand what I'm seeing from the various tools available to me. Humbly, David |
Re: Gain plugin and RMS calculation
I believe there may be a bug related to the "handle" setting in the lower right corner of the Audiosuite plugin. Make sure to set that to 0.00, or it will take the handle length into account in the RMS analysis, which will throw off the reading.
Scott Gatteño |
It's a different definition of 0dB RMS. The difference is 3(.01)dB.
AES standard: 0dBFS sine wave = 0dB RMS ITU standard: 0dBFS square wave = 0dB RMS Protools is using the ITU standard so it reads lower compared to some other software. Last edited by Farhoof; 10-08-2018 at 02:52 PM. |
Thank you so much for the explanation. I wound up assuming something like that, but your confirmation is greatly appreciated for the next time this comes up.
David |
I have a similar situation to the original poster. I'm used to mixing / mastering music based on the usual Volume Wars / streaming loudness parameters. But I have a bunch of audiobook masters I need to deliver between -24dB to -14dB RMS. I had never known about or used the Gain Audiosuite plugin before, so this is great. But do I infer from some of the above comments that the Gain plugin RMS reading is 3(.01)dB lower than the more commonly used standard for calculating RMS? I can always just shoot for -18dB and be in the ballpark I guess, with 3dB margin for error on either side . But would love any tips or suggestions. Thanks!!
You may want to invest in this.
Thanks. Downloaded the Nugen VisLM trial, and between that and the Gain Audiosuite plugin I'm just going for it, trying to shoot in between -24 and -14. From Googling around a bit, it seems that requesting RMS specs without specifying which standard is basically providing incomplete specs... But what do I know? Usually I'm just trying to make stuff loud!
Gain riding plugin | Ted Blaisdell | VENUE Live Sound Systems | 6 | 01-21-2013 04:41 AM |
Plugin raises gain 3db? | madlo | macOS | 1 | 07-08-2012 03:05 AM |
Audio Suite - Gain Plugin…..???? | YYR123 | Pro Tools 9 | 2 | 04-08-2012 08:51 PM |
Is it better to use a Trim plugin or Gain plugin? | SpinningDisk | Tips & Tricks | 5 | 01-19-2010 02:43 PM |
As Gain Plugin in PT 8.03 | m4tune | Pro Tools TDM Systems (Mac) | 2 | 01-15-2010 09:07 AM |
