Old 05-31-2011, 11:32 AM
uzi B uzi B is offline
Default Dubbing
hi, i like your forum.
i would like to know if i need to stop and record and hen stop again and record again for dubbing, or if i can mark several locations and get protools to give me clicks before each recording???
i hope someone will have an answer for it :)
Thanks.
Old 06-01-2011, 09:49 AM
Styles Bitchly Styles Bitchly is offline
Default Re: Dubbing
I'm assuming you're recording VOs, right? What I typically do, if I'm the voice talent, is to record a loud "tongue click" each time I make a mistake. The click shows up as a quick transient in the waveform, marking the beginning of the new take.
If you're doing the recording, you can set markers by pressing the "enter" key on the keyboard. You then have the ability to name the location if you like. If you want to just enter the marker quickly you'll just need to hit the enter key twice during the recording. I hope this helps you out.
Due to budget cuts the light at the end of the tunnel will be turned off until further notice.
http://www.gidakdigital.com
Old 06-01-2011, 10:45 AM
Default Re: Dubbing
thanks for your answer, but i am not sure i explained myself correctly.
let say i video taped you. now, each time you are speaking on the video, i want to marked it in order to get 2 or for clicks noticed before it's get into record (like pre or post roll) .
instead of stopping each time i was wondering if you can mark several locations, and when the courser gets to each and one of them it stops and give you clicks before it gets in to record.
i hope i explained myself right :)
Old 06-01-2011, 03:09 PM
Default Re: Dubbing
Yeah, I think I know what you're talking about. Apparently you're using video in PT, right? PT will do a pre-roll count for you, but only at the beginning of the spot you want to record, and it won't stop at multiple places and play the count off - not as far as I know anyway.
The only way I can think of to do this would be to create a separate audio track, and record actual audio clicks at the exact places that correspond to the video track. Does that make sense? Maybe I'm way off base with what you're trying to do, but I'm doing my best to help.
Old 06-01-2011, 04:17 PM
Default Re: Dubbing
exactly, that's what i meant... thank you very much.
HD Native For Dubbing... OK? Picture Start Post - Surround - Video 12 06-06-2012 12:47 PM
Dubbing to Picture LE v's HD simms Post - Surround - Video 5 04-11-2008 09:37 AM
Dubbing Wavedude 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 02-19-2008 07:07 PM
Dubbing LCD vs CRT MusoPro Post - Surround - Video 1 12-05-2006 06:26 AM
Tips for dubbing Procuro Post - Surround - Video 4 11-30-2006 11:53 AM
