Old 02-15-2012, 05:03 AM
Firechild Firechild is offline
Default Re: Can I use 2 hd core card?
Correct, if you want to waste twice as many PCI slots I agree completely that two Process cards are better than 1 Accel card, however there is still a limit of up to 6 HD cards
iMac Pro - HDX2 - Mojave - AVID HD I/O x7
Old 02-16-2012, 01:43 AM
Are you sure? Digitest shows more slots... Anyway, just a thumbs-up because those old original PCI Process cards can be bought dirt cheap and they're perfectly capable cards, if you have a slot to put them into
Old 02-01-2018, 01:40 AM
lonestars lonestars is offline
Reopening this thread...
If i have this configuration:
HD|Core
HD|Core
HD|Accel
Do you know if Flexcable is needed between the first and second HD|Core cards? Obviously between second HD|Core and HD|Accel is needed, but someone can tell me if is needed between HD|Core cards?
Thank you!!.
Quim
Old 02-01-2018, 06:18 AM
crizdee's Avatar
crizdee crizdee is offline
HD|Core
HD|Core
HD|Accel
Thank you!!.
Quim
Yes
Chris
Producer, Engineer,
www.ukmastering.com
Old 07-06-2020, 02:12 AM
$BIGGROBB$ $BIGGROBB$ is offline
opening this again!!
I have:
3 - 192 i/o
3 - Core Cards
3 - Accel Cards
2 - process cards
pro tools 10hd with magma 13 slot expansion chassis
is there any benefit to using all 3 core cards then all 3 accel cards and one process card? Will I have same power if I only use 1 core and 3 accel cards?
should i bypass the additional core cards and go 1 core and 3 accel?
all help appreciated!
Old 07-06-2020, 02:16 AM
If you have old PCI cards, Core card equals Process card.
Old 07-06-2020, 05:18 PM
They are all PCI cards in an expansion bay, correct. Is there any benefit to using all 7 cards with 3 192’s?
How would you order them in your slots?
3 - HD Core cards
3 - HD Accel cards
2 - Process cards
Old 07-06-2020, 05:21 PM
Card order *must* be core card first, accel cards second, process cards last. Now back in the day core card was the most expensive so not many had more than one in a system, I am not so sure if you need to put all core cards first. Knowing core card is identical to process card (except the core capability) you may need to put rest of the core cards after accel cards. Just try it.
Old 07-09-2020, 01:41 AM
the order that was functional initially was as follows
slot 1 - core card
slot 2 - core card
slot 3 - process card
slot 4 - process card
slot 5 - process card
I did not check if computer registered all cards prior to test, but i took them out and added
slot 1 - core card
slot 2 - accel card
slot 3 - accel card
slot 4 - core card
slot 6 - process card
slot 7 - process card
...PT WOULDNT EVEN START, the computer wouldnt start either
so I tried...
slot 1 - core card
slot 2 - accel card
slot 3 - accel card
slot 4 - core card
same thing, wouldnt start nothing would
so I tried...
slot 1 - core card
slot 2 - accel card
slot 3 - accel card
slot 4 - accel card
computer said tdm cable was unplugged and it wasnt and I tried numerous tdm cables
so I ...
slot 1 - core card
slot 2 - accel card
slot 3 - accel card
and it worked(but only with the tdm cables that WERE MADE IN CHINA! The usa made tdm cables did not work at all, sadly). voice count was low, and if I try and use more than 1 dsp in the playback engine, it will crash and upon restart will go back to 1 dsp...
damn
PT HD1 (core card PCI) x PTHD1(Accel core card PCIE) Alécio Costa Pro Tools TDM Systems (Mac) 6 05-02-2017 06:52 AM
Using a PCIe core card as additional Accel card? Firechild Pro Tools TDM Systems (Mac) 3 07-30-2012 10:48 PM
192 not recognized from Core card, but IS from Accel Card. Advice? Mt.Everest Pro Tools TDM Systems (Mac) 5 05-24-2010 09:14 PM
Is every HD Core PCIe card an Accel Core Card? Matiz Pro Tools TDM Systems (Win) 3 06-11-2006 09:05 PM
HD Core card to Accel card flex cable in Dell 670 belouder Pro Tools TDM Systems (Win) 4 01-16-2006 07:55 PM
