Old 12-22-2002, 09:02 AM
Big Tyme Big Tyme is offline
Default What is the difference between Korg Triton Classic and Triton LE???
I am interested in purchasing a Korg Triton but I don't know what the difference is between the two. Which is the better of the two?? Is there any major difference in features?? Any help will be appreciated. Thanks!
Old 12-22-2002, 09:36 AM
ReniuR ReniuR is offline
Default Re: What is the difference between Korg Triton Classic and Triton LE???
The LE model doesn't have touchscreen, or a sampler built-in, or the digital outs and 4 analog outs instead of 6. The sequencer and sounds are the same as well as the synthesys engine itself. Other than those, I don't think there are any other big differences.
We got a Karma shortly before they put out the Triton LE. These 2 boards are almost the same as well. We haven't used the arpegiator of the board very much (mostly sequencing) and I have to say that the sequencer is very user friendly.
-ReniuR
www.disposableproductions.com
Old 12-22-2002, 11:28 AM
FrankLP FrankLP is offline
If you go to www.korg.com you can compare features for yourself (as well as listen to demos).
Old 12-22-2002, 06:00 PM
Captain_Pants Captain_Pants is offline
As Ruiner(from the NIN song?) pointed out, they are almost the same. Keep in mind, for $200, you can add a sampler to the LE. Some will say the sounds are better on the Triton Classic, but both units use the same sound banks, so I throw that theory out the door. I have an LE, and run it through a good mixer with good cables, and I get great sounds all the time. I dont know if you have been using synths for a while, or if you are new, but one thing I have learned is that if you want good natural sounds(strings, drums, brass, piano, etc..) go with Roland. If you are more into electronic, then I find the Korgs to be better..
Of course, you might not even be interested in buying and just generally curious. Who knows but you.
=-CP.
Ill suffer winter alone;
ten thousand miles from home...
Korg Triton and PT 7.1 foxlemieux Tips & Tricks 8 10-24-2007 09:54 PM
korg - triton jiff MIDI 0 03-02-2003 10:34 PM
Which one to get? (Kurzweil K2600 or Triton LE, Classic or Studio) Mastersonics Pro Tools TDM Systems (Mac) 6 02-13-2003 08:46 AM
What is the difference between Korg Triton Classic and Triton LE??? Big Tyme 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 12-23-2002 04:50 AM
Korg Triton & Mac G3 Dr. J Pro Tools TDM Systems (Mac) 1 03-18-2001 09:08 AM
