Old 06-08-2003, 08:24 AM
Overlord of the Undertone Overlord of the Undertone is offline
Default Export Regions & Roxio Jam
I'm trying to figure out how I can avoid "bounce to disk" when using PTLE and Roxio Jam. I have a 2 trk Master recorded at 44.1 and I've captured the desired regions and exported them. Is there a way to get Jam to import these regions as tracks?
Old 06-08-2003, 09:12 AM
where02190 where02190 is offline
Default Re: Export Regions & Roxio Jam
I just did this with a live recording that was one continious file. I separated the regions, selected all the regions and from the audio drop down menu of the edit window, exported selected as files. selected wav/16 bit/stereo. Once complete, I opened Jam, dragged the exported files into the Jam window, set the track gap to 0:00:00 and burned. worked perfectly.
Hope this is helpful.
Old 06-08-2003, 09:56 AM
raswoods raswoods is offline
using the "export selected as files, however, doesnt utilize any plug-ins on that track or master fader, so if you are using plug-ins....BTD or recording to 2 new mono tracks works best...
when we are not havin fun, its time to go home
Old 06-08-2003, 02:10 PM
If you're not doing any processing to the regions.. then simply use the Region menu item: Export Region Definitions and in Jam add the regions instead of the files.
Rail
Platinum Samples
www.platinumsamples.com
Engineered Drums for BFD
Old 06-08-2003, 02:24 PM
lcouri lcouri is offline
what about if you're working in 24bit 48khz and you need to dither down to 16 bit, do you have to bounce or can you export to 16bit ie. is export dither better than the plug in dither?
002R; G4 Powerbook 1.5Ghz 1GB RAM OSX 10.3.4
Firewire 800 external drive
001; G4 533 1GB RAM OSX 10.2.8
Old 06-08-2003, 05:03 PM
Wow. Export as files works great! I do alot of 2 trk processing of live shows. Very nice. However, I tried to get Jam to see the regions, but it doesn't. Since I didn;t use any plugins I'm good to go. If I wanted to use plugins, I save the tracks as two mono tracks? Whats BTD?
Thanks all for your suggestions. You just saved me ALOT of time!
Export Regions as Files BUG? napobu Tips & Tricks 3 10-18-2013 11:10 AM
can't export regions anymore? synergyscott 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 03-06-2011 10:56 AM
export regions as files acetboy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 09-05-2007 09:12 PM
Export Regions with RTAS kamoni 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 03-27-2006 06:08 AM
Export Regions to Files ?? lelliott General Discussion 2 06-22-2000 02:11 PM
