The dreaded H/W Buffer Size (Error 9092) message...
Ok, I am officially out of ideas. I've recently put together a PC and am now trying to get my usual Pro Tools stuff working. Whenever I try to record on Pro Tools (Mbox2 Pro, Pro Tools 8.0.5) I get the Error 9092 message. I've tried adijusting the buffer (all settings), deleting my prefs, making sure I'm NOT running on RAID, turning my wifi and virus protection off, making sure my Firewire is running in Legacy (via device mamager) mode, uninstalling and reinstalling Pro Tools and nothing has worked.
I'm fearing I have some kind of compatibility issue, but I can't put my finger on it. I'm posting my SANDRA report below, hopefully someone could help me out. ***** Start of Report ***** -------------------------------------------------------------------------------- <<< Computer Overview >>> -------------------------------------------------------------------------------- < Computer > Model: Gigabyte P67A-UD3-B3 Workgroup: WORKGROUP Host Name: Owner-PC User: Owner < Processor > Model: Intel(R) Core(TM) i7-2600 CPU @ 3.40GHz Speed: 3.5GHz Cores per Processor: 4 Unit(s) Threads per Core: 2 Unit(s) Type: Quad-Core Integrated Data Cache: 4x 32kB, Synchronous, Write-Thru, 8-way, 64 byte line size, 2 threads sharing L2 On-board Cache: 4x 256kB, ECC, Synchronous, ATC, 8-way, 64 byte line size, 2 threads sharing L3 On-board Cache: 8MB, ECC, Synchronous, ATC, 16-way, Exclusive, 64 byte line size, 16 threads sharing < Computer > Mainboard: Gigabyte P67A-UD3-B3 BIOS: Award (Phoenix) F2 02/22/2011 Bus(es): X-Bus PCI PCIe IMB USB FireWire/1394 i2c/ SMBus Multi-Processor (MP) Support: No Multi-Processor Advanced PIC (:Yes Total Memory: 8GB DIMM DDR3 < Chipset > Model: Intel Core (Sandy Bridge) DRAM Controller Front Side Bus Speed: 100MHz Total Memory: 8GB DIMM DDR3 Channels: 1 Memory Bus Speed: 2x 667MHz (1.33GHz) < Memory Module(s) > Memory Module: Corsair CMX8GX3M2A1600C9 4GB DIMM DDR3 PC3- 12800U DDR3-1600 (9-9-9-24 5-34-10-5) < Video System > Video Adapter: NVIDIA GeForce 210 (16 SM4.1 1.4GHz, 512MB DDR2 128-bit, PCIe 2.00 x16) < Graphics Processor > OpenCL Processor: NVIDIA GeForce 210 (16SP 2C 1.4GHz, 512MB DDR2 128-bit) Compute Shader Processor: NVIDIA GeForce 210 (16SP 1.4GHz, 512MB DDR2 128-bit) < Storage Devices > Hitachi HDS5C3020ALA632 2TB (S:2TB (C:) LaCie d2 quadra 1TB (FireWire/:932GB (E:) Seagate ST31000528AS (1TB, Fir:932GB (F:) HL-DT-ST DVDRAM GH22NS50 (SATA:N/A (D:) < Logical Storage Devices > System Reserved: 100MB (NTFS) LaCie (E:): 932GB (NTFS) @ LaCie d2 quadra 1TB (FireWire/ 1394) Audio 1 (F:): 932GB (NTFS) @ Seagate ST31000528AS (1TB, FireWire/1394/SATA, 3.5") Hard Disk (C:): 2TB (NTFS) @ Hitachi HDS5C3020ALA632 2TB (SATA600, 3.5", 5940rpm, 26MB Cache) Optical Drive (D:): N/A @ HL-DT-ST DVDRAM GH22NS50 (SATA150, DVD+- RW, CD-RW, 2MB Cache) < Peripherals > LPC Hub Controller 1: Giga-Byte Cougar Point LPC Controller LPC Legacy Controller 1: T2 87-28 Audio Device: Giga-Byte Cougar Point High Definition Audio Controller Audio Device: MSI High Definition Audio Controller Audio Codec: nVidia 000Bh Audio Codec: 1 0001h Audio Codec: 1 0001h Serial Port(s): 1 Disk Controller: Giga-Byte Cougar Point 4 port SATA IDE Controller Disk Controller: Giga-Byte Cougar Point 2 port SATA IDE Controller Disk Controller: Jmicron JMB36X PCIE-to-SATAII/IDE RAID Controller USB Controller 1: Giga-Byte Cougar Point USB Enhanced Host Controller #2 USB Controller 2: Giga-Byte Cougar Point USB Enhanced Host Controller #1 USB Controller 3: Giga-Byte uPD720200 USB 3.0 Controller FireWire/1394 Controller 1: 22785 FW643 PCI Express1394b Controller (PHY/ Link) FireWire/1394 Controller 2: VIA VT6306 VIA Fire II IEEE-1394 OHCI Link Layer Controller SMBus/i2c Controller 1: Intel ICH SMBus < Printers and Faxes > Printer: Send To Microsoft OneNote 2010 Driver (1200x1200, Colour) Printer: Microsoft XPS Document Writer (600x600, Colour) Fax: Microsoft Shared Fax Driver (200x200) Printer: EPSON NX420 Series (360x360, USB, Colour) < Network Services > Network Adapter: Realtek PCIe GBE Family Controller Wireless Adapter 1: D-Link DWA-552 XtremeN Desktop Adapter (802.11n (HT), AES-CCMP, 130Mbps) < Power Management > Mains (AC) Line Status: On-Line < Operating System > Windows System: Microsoft Windows 7 Home 6.01.7600 Platform Compliance: x64 <<< Mainboard >>> -------------------------------------------------------------------------------- < Computer > Manufacturer: Gigabyte Model: P67A-UD3-B3 ID: 00000000-00000000-6F1C0000-C751D565 < Computer Chassis > Manufacturer: Gigabyte Type: Desktop Can be locked: No < Mainboard > Manufacturer: Gigabyte Multi-Processor (MP) Support: No Multi-Processing (MPS) Version:1.40 Model: P67A-UD3-B3 Version: x.x BIOS: 02/22/2011-P67-7A89VG0BC-00 Chipset: A89V < Computer Memory Controller > Location: Mainboard Error Correction Capability: None Number of Memory Slots: 4 Maximum Installable Memory: 32GB Bank0/1 - A0: DIMM 4GB/2304 @ 1.33GHz Bank2/3 - A1: DIMM 4GB/2304 @ 1.33GHz Bank4/5 - A2: Empty Bank6/7 - A3: Empty < Chipset > Model: Intel Core (Sandy Bridge) DRAM Controller Revision: A10 Bus: Intel CSI (Quick Path) Front Side Bus Speed: 100MHz Width: 20-bit / 20-bit HTT - Hyper-Threading Technolo:Yes Maximum Bus Bandwidth: 400MB/s Maximum Power: 3.40W < Features > VT-d - Virtualisation Technolo:Yes < Chipset 1 Hub Interface > Type: DMI (Direct Media Interface) Version: 1.00 Number of Ports: 4 In/Out Width: 4-bit / 4-bit Full Duplex: Yes Multiplier: 6x Speed: 200MHz < Logical/Chipset Memory Banks > Bank 0: 4GB DIMM DDR3 9-9-9-24 5-33-10-5 1T Bank 1: 4GB DIMM DDR3 9-9-9-24 5-33-10-5 1T Supported Memory Types: DIMM DDR3 Channels: 1 Memory Bus Speed: 2x 667MHz (1.33GHz) Maximum Memory Speed: 2x 666MHz (1.33GHz) Multiplier: 20/3x Width: 64-bit Integrated in Processor: Yes Power Save Mode: No Fixed Hole Present: No Maximum Memory Bus Bandwidth: 10.42GB/s < APIC 1 > Version: 2.00 Multiplier: 1/2x Maximum Interrupts: 24 IRQ Handler Engaged: Yes Enhanced Support: Yes < Memory Module > Type: 4GB DIMM Speed: PC10600U < Memory Module > Type: 4GB DIMM Speed: PC10600U < Sensors 1 > Model: Intel Core CPU [P0, C4, T98] Version: 42.07 Mainboard Specific Support: No < Temperature Sensor(s) > CPU 1 Temperature: 42.00°C < System Bus(es) on Hub 1 > Version: 2.30 System Bus 0: PCI System Bus 1: PCIe 2.00 x16 2.5Gbps System Bus 2: PCIe 2.00 x1 2.5Gbps System Bus 3: PCIe 2.00 x1 5Gbps System Bus 4: PCIe 2.00 x1 2.5Gbps System Bus 5: PCIe 2.00 x1 2.5Gbps System Bus 6: PCI66 System Bus 7: PCIe 2.00 x1 2.5Gbps < LPC Hub Controller 1 > Model: Giga-Byte Cougar Point LPC Controller OEM Device Name: Intel Cougar Point LPC Controller Revision: A6 ACPI Power Management Enabled: Yes Advanced TCO Mode Support: Yes Advanced TCO Mode Enabled: No High Precision Timer Enabled: Yes Number of Precision Timers: 8 System Timer: 14.32MHz Delayed Transaction Enabled: Yes < LPC Legacy Controller 1 > Type: T2 87-28 Version: 0.28 Number of Enabled Devices: 5 < Disk Controller > Model: Giga-Byte Cougar Point 4 port SATA IDE Controller OEM Device Name: Intel Cougar Point 4 port SATA IDE Controller Interface: SATA Revision: A6 Maximum SATA Mode: G2 / SATA300 RAID Support: Yes RAID Enabled: No Channels: 4 In Use Channels: 2 Port: G2 / SATA300 Port: G2 / SATA300 < Disk Controller > Model: Giga-Byte Cougar Point 2 port SATA IDE Controller OEM Device Name: Intel Cougar Point 2 port SATA IDE Controller Interface: SATA Revision: A6 Maximum SATA Mode: G2 / SATA300 RAID Support: Yes RAID Enabled: No Channels: 2 < Disk Controller > Model: Jmicron JMB36X PCIE-to-SATAII/IDE RAID Controller OEM Device Name: Jmicron JMB36X PCIE-to-SATAII/IDE RAID Controller Interface: SATA Revision: B1 Specification: 1.10 Maximum SATA Mode: G2 / SATA300 Channels: 2 < Audio Device > Model: Giga-Byte Cougar Point High Definition Audio Controller OEM Device Name: Intel Cougar Point High Definition Audio Controller Revision: A6 Type: HD (High-Definition) Audio Version: 1.00 Number of In / Out / Bi-Direct:4 / 4 / 0 Number of Serial Data Streams: 1 < Audio Device > Model: MSI High Definition Audio Controller OEM Device Name: nVidia High Definition Audio Controller Revision: K2 Type: HD (High-Definition) Audio Version: 1.00 Number of In / Out / Bi-Direct:4 / 2 / 0 Number of Serial Data Streams: 2 < Audio Codec > Model: nVidia 000Bh Revision: A1 < Audio Codec > Model: 1 0001h Revision: A1 < Audio Codec > Model: 1 0001h Revision: A1 < USB Controller 1 > Model: Giga-Byte Cougar Point USB Enhanced Host Controller #2 OEM Device Name: Intel Cougar Point USB Enhanced Host Controller #2 Revision: A6 Version: 2.00 Specification: 1.00 Interface: EHCI Channels: 2 Supported Speed(s): Low (1.5Mbps) Full (12Mbps) High (480Mbps) Addressing Support: 64-bit Legacy Emulation Enabled: No < USB Controller 2 > Model: Giga-Byte Cougar Point USB Enhanced Host Controller #1 OEM Device Name: Intel Cougar Point USB Enhanced Host Controller #1 Revision: A6 Version: 2.00 Specification: 1.00 Interface: EHCI Channels: 2 Supported Speed(s): Low (1.5Mbps) Full (12Mbps) High (480Mbps) Addressing Support: 64-bit Legacy Emulation Enabled: No < USB Controller 3 > Model: Giga-Byte uPD720200 USB 3.0 Controller OEM Device Name: NEC uPD720200 USB 3.0 Controller Revision: A5 Version: 3.00 Interface: XHCI Legacy Emulation Enabled: No < FireWire/1394 Controller 1 > Model: 22785 FW643 PCI Express1394b Controller (PHY/ Link) OEM Device Name: Lucent/Agere Systems (Was: AT&T MicroElectronics) FW643 PCI Express1394b Controller (PHY/Link) Revision: A9 Version: 1.10 Interface: OHCI Enhanced Support: Yes Speed: 400MHz < FireWire/1394 Controller 2 > Model: VIA VT6306 VIA Fire II IEEE-1394 OHCI Link Layer Controller OEM Device Name: VIA VT6306 VIA Fire II IEEE-1394 OHCI Link Layer Controller Revision: I1 Version: 1.00 Interface: OHCI Enhanced Support: No Speed: 400MHz < SMBus/i2c Controller 1 > Model: Intel ICH SMBus Version: 0.05 Specification: 2.00 Advanced TCO Mode Enabled: No Slave Device Enabled: Yes PEC Support: Yes Speed: 100kHz < Expansion Slot(s) > PCI: PCI 32-bit +5V +3.3V PME i2c/SMBus Full Available PCI: PCI 32-bit +5V +3.3V PME i2c/SMBus Full Available < Port Connector(s) > PRIMARY IDE: ATA SECONDARY IDE: ATA FDD: 8251 FIFO / Floppy Disk COM1: Serial Port 16450 / 9 Pin Dual Inline / DB-9 pin male COM2: Serial Port 16450 / 9 Pin Dual Inline / DB-9 pin male LPT1: Parallel Port ECP/EPP / DB-25 pin female / DB- 25 pin female Keyboard: Keyboard / PS/2 PS/2 Mouse - No Detected: Mouse / PS/2 / PS/2 USB: USB / USB USB: USB / USB < Performance Enhancing Tips > Warning 2534: Enabling disabled host controllers is risky! Notice 224: SMBIOS/DMI information may be inaccurate. Tip 2511: Some memory slots are free so the memory can be easily upgraded. Tip 2: Double-click tip or press Enter while a tip is selected for more information about the tip. |
Re: The dreaded H/W Buffer Size (Error 9092) message...
Did you also try reducing the number of cores used by Pro Tools?
Setup>Playback Engine>Host Processors
I've tried eliminating one (0, specifically), than just working on a single processor--neither have worked.
Update: I've also tried uninstalling all NVIDIA video drivers (running on generic VGA interface at the moment) and audio codecs, STILL nothing.
Why does the Sandra say the system has 8GB of total RAM, but only show 1 stick of 4GB?
"Why does the Sandra say the system has 8GB of total RAM, but only show 1 stick of 4GB?"
Beats me. The computer says 8GB, and there are indeed two identical sticks of 4GB in the box. |
maybe not any help, but I didn't see any info on your audio drive, (speed/ cache)? I'm also curious about the 'C' drive at 5940 RPM/ and 26 MB cache? And your audio drive (drives ?) are Fire Wire,,, (Your 'F' drive says FW 1394/ SATA 3.5?) Also, noticed that RAM timing is 9-9-9-24,,, is this common for this RAM/MOBO combo? I haven't researched these, nor am I familiar with the newer drives out there! I'm just wondering if your bottle neck is your audio drive? really should be 7200 RPM and best with 32 MB cache (and internal)??? Best of luck! ---- Mike
Intel Core i7 4790K 4.0GHz | Asus Z97-Pro LGA 1150 Intel 6Gb | Corsair Vengeance Pro 32GB DDR3 2400 | Asus GT640 Silent 2 GB GDDR3 | Samsung 850 Pro SSD's, WD Caviar Black HDD's | PSU Corsair 750W ATX12V | Windows 10 | Presonus Studio One | 003R PT's 12.8 | Waves Platinum | Ivory/Piano | Berlin Woodwinds, Nocturne Solo Violin | SPITFIRE Solo Strings | EastWest Hollywood Strings, Brass, Pro Drummer, and Stormdrum 2 | VSL | Vienna Ensemble Pro | M-Audio Code 61, FaderPort 8 | |
Another thought,, I just read another thread answered by 'the weed',, and he mentioned that a VIA FW controller can be a problem,, ( your fire wire 2 has a VIA controller!). ------- Mike
For some reason my C drive is only clocking at 26MB cache, though it's rated at 32 MB (if memory serves), my Buffalo external drive has an internal SATA drive, it runs to the computer via firewire--it IS rated at 7200RPM and 32MB cache, so I don't know what's going on there. I'm afraid I'm not quite experienced enough to understand what RAM timing is (I've only been playing with building and cracking open computers for about a month). As per your other post, I have two sets of Firewire ports (2-800, 1-400 and another pair of 400's), I've tried them both and still nothing. I'm seriously thinking about converting this damn thing into a Hackintosh... |
try reseating both memory sticks, ensure that it is actually making contact with the motherboard connector. It could explain the reason only 1 stick is showing.
Nick
Core i7 920 OC'ed @ 4.0 GHz (200 X 20) 12 GB Patriot Viper Extreme Asus P6T OCZ Agility 64 GB SSD Hitachi 1TB 32 MB HDD WD Caviar Black 500GB Saphhire HD 5850 3 x 20" monitors Eleven Rack w/ ERXP Fender Super Champ XD Marshall JCM2000 DSL100 Silver Edition W/ Silver Jubilee Cabinet |
The dreaded decrease/increase buffer error message | hnbike | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 9 | 02-01-2009 11:15 AM |
9092 error H/W buffer size | Murt | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 22 | 04-22-2008 11:18 AM |
Buffer size error -9092 still cannot fix | AuAu | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 03-28-2008 08:55 PM |
Increase H/W Buffer Size - Error 9092 | rainmaker | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 10 | 08-09-2007 09:35 AM |
H/W buffer size (-9092) message | Sergio Veliz | Digidesign Hardware & Software | 5 | 03-22-2001 01:11 PM |
