Old 12-26-2010, 09:50 AM
anothercolour anothercolour is offline
Default Structure 1.1 Error Saving Patches
Hello all,
I just purchased Structure 1.1, and I'm having problems saving patches.
Here's the situation:
I make a patch from my own samples and save it to disc.
I then further edit the patch and attempt to save my new edits.
When I save over the previously written patch, I receive a message that reads:
"An error occurred while writing the patch file."
The patch is no longer usable from this point.
Is anyone else experiencing this?
I'm on a Mac, OS 10.6.5 with Pro Tools HD9.
Thank you.
Old 12-26-2010, 12:21 PM
Default Re: Structure 1.1 Error Saving Patches
If you create a new session and run a dummy test can you reproduce?
Aaron Mulqueen - 001 HD Native
Old 12-26-2010, 02:04 PM
Yes, it happens with all my sessions. I'm at the point now where I can't save anything with Structure.
I'm a big fan of reformatting and installing everything clean, and that's what I'm going to do now.
Thanks for the reply.
Old 12-26-2010, 11:51 PM
Keep us updated.
Old 12-27-2010, 01:52 AM
Top Jimmy's Avatar
The problem is that you are trying to save over the original patch. This has been a long-time problem with Structure. You have to save as a different name.
Also, if you try to delve into the metadata editing in the database, you'll find problems there too when writing back to the patch..
James Cadwallader
Old 12-27-2010, 10:20 AM
I completed a fresh install of OSX, Pro Tools, and the Instrument Expansion Pack. I receive the same error when saving over the patch.
Now I see Top Jimmy's post. Thank you for the information.
I will try a few patches saving with different names.
Thanks again.
Old 12-27-2010, 12:15 PM
Long standing problem for Mac as I have not seen that problem on PC for any version of Structure.
Old 12-27-2010, 01:53 PM
When I do not save over a patch using the same name, Structure works perfectly. It's probably a better work flow to save incrementally with different names, anyway.
Thank you for the much needed information.
As one thing leads to another, I've started a new thread with a related question that has now arisen.
Maybe one of you can shine some light on the following:
http://duc.avid.com/showthread.php?t=290754
Thanks again
Old 12-27-2010, 04:56 PM
Top Jimmy's Avatar
IIRC, it's monolithic files that are the problem. I just tried in Structure LE 1.0.5 on PC and a patch with external samples would overwrite but a monolithic patch would not.
James Cadwallader
Old 12-27-2010, 07:35 PM
Overwriting Monolithic Patches with Structure does not have this problem. Interesting Top Jimmy.
Saving structure patches in bulk suicune Pro Tools TDM Systems (Mac) 4 04-27-2009 11:52 AM
Method of saving all patches at once in Structure? Stuart P. Virtual Instruments 1 04-06-2008 01:03 AM
Saving Xpand! patches davegibbon Virtual Instruments 3 12-07-2007 06:32 AM
Saving POD Patches In LE 7.3 rkaynan 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 09-29-2007 10:02 PM
Saving Patches in PT Hardnox MIDI 0 10-28-2001 06:32 PM
