No Eleven LE presets Win 7 x64
Hi. I just built a new computer and upgraded to MPTK 2. Everything else works great, but when I open Eleven LE, there are no Eleven LE presets, just the default setting. Eleven Free and presets work. In DAE/Plug-Ins I see 24 entries related to Eleven including "Eleven LE.dpm" and "Eleven LE.dpm.rsr". I did and un and re-install, rebooting between each operation. I did a search before posting but didn't see anything but going to AIR blog. Went there and didn't find what I need. Any ideas? Thank you.
PTLE 8.0.4 Win 7 64 bit 002 rack
Digi002R PT2018 Win 10 INTEL Core i7 930, 3.52 Ghz GIGABYTE GA-X58A-UD3R CORSAIR XMS3 12GB 1600Mhz 2 X WD 1TB Caviar Black 64 GB cache MOTU Traveller PT2018 MacBook Pro Mojave 16GB DDR3 |
Re: No Eleven LE presets Win 7 x64
hmm, did you re-install Eleven? I have eleven and the presets are there. I'll email em to you if you dont get it worked out.
By the way, they file path to the presets for Eleven Rtas is Programs Files (x86)> Common Files>Digidesign>DAE>Plug-In Settings > Eleven
Brian Windows 11 Pro | macOS 12 Pro Tools 2022 benonistudio.com Youtube Channel - benonistudio Plugin Deals @benonistudio |
I found Eleven installer on Avid site, but have not installed it yet. Should I try that first? I thought it might lead to some redundancy issues. And yes, that is the path I used. Thanks.
So the Eleven Preset folder is Empty? If you dont get it worked out, just email me (click my name) and i'll zip up the preset folder and email it to you. I (of course) have the factory presets, plus a bunch from Cary http://duc.digidesign.com/showpost.p...9&postcount=63
Eleven LE doesn't show up individually on the Win Programs list - only the whole MPTK2 pkg. So I cannot see how to uninstall it. There IS an "ElevenRack Driver 1.0.8 (x64)" but I don't think I should try that uninstall, just yet. Or should I?
Yes Preset folder is empty. I will use the Eleven installer, after making a TI back up, and if that is not good, I will take you up on your kind offer!
Well, the separate Eleven installer fixed it! Thanks Benoni.
Eleven presets disappeared | WildHoney | Pro Tools TDM Systems (Mac) | 0 | 05-25-2012 04:20 PM |
Create Eleven Presets in PT | sinestro.f | Eleven Rack | 1 | 12-04-2011 06:01 PM |
Eleven Rack Presets Unavailable | joedexter23 | Eleven Rack | 4 | 07-19-2011 05:07 AM |
Eleven LE presets missing | SteveFireland | Pro Tools M-Powered (Win) | 3 | 12-12-2009 04:02 AM |
Eleven User Presets? | AndyJCP | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 03-02-2009 05:46 PM |
