Distortion/crackling clips
Hi all,
I've reported this a couple of times on here but I thought I'd give it another shot as it has really pi$$ed me off this time. Here are two clips of a bass track from the same session... the first one is fine (bar the sound, playing etc ) but the second (from a different take) has the distortion on it. http://fm.stevemoore.tv/delta.mp3 http://fm.stevemoore.tv/delta-borked.mp3 I'm monitoring through the Delta 1010lt and it sounds fine... but PT records that crazy distortion. Monitoring through PT, it sounds like that but I pretty much never do that due to latency issues. So I usually don't notice it has happened until I listen back to the take. Sometimes it'll happen after a few hours of using PT, sometimes one the first go. Seems pretty random. Has happened in every version of PT8, and on two totally different PCs. Never ever had this problem in 7.4 on the same hardware. When it happens, it's easy to fix by H/W Buffer Size to something and then changing it back - but when you don't notice it until you play back a 5 minute take, it's guitar-smashingly annoying!!! I've tried posting on the M-Audio forums but I may as well have printed it out and mailed it straight to the moon for all the use they are over there. But I do know that other people have experienced the same thing... Anyone got any ideas? Steve.
http://www.stormzone.tv |
Re: Distortion/crackling clips
Stave,
I am by far no expert on Pro Tools, but have you downloaded the new cs 2 update? The reason I ask is because I had similar (white noise?) conditions and this update worked for me. Anyways, I just wanted to ask and take care! |
mbox2 periodic crackling and distortion | grafic | macOS | 11 | 02-14-2015 10:38 AM |
Bug: X-Form replaces clips with distortion | iain_m | RTAS & TDM Plug-ins | 2 | 08-16-2013 05:58 AM |
Elastic Audio - Crackling, Popping, and Distortion | lclebsch | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 11 | 10-08-2009 05:24 PM |
Smack! causing HORRIBLE distortion crackling problems | ProToolsIgniter | Pro Tools TDM Systems (Mac) | 2 | 05-23-2007 08:40 PM |
bizarre crackling distortion | InjuredEar | Pro Tools TDM Systems (Mac) | 5 | 03-22-2006 07:40 PM |
