Old 11-28-2009, 01:28 PM
stratquebec stratquebec is offline
Default Vertical zoom key command
Thanks in advance.
What's the key command to zoom in and out all the tracks in the arrange window ?
(the same way as when you click on the + and - signs under the vertical scroll bar)
iMac 27 inches , late 2012, Quad-core, 8 GB ram, Fusion Drive, 3,4 GHz Intel Core i7, MacOs Mojave 10.14.6, Focusrite Saffire Le, thunderbolt adaptor, 800/400 FW cable.
Old 11-28-2009, 07:20 PM
Default Re: Vertical zoom key command
No answer?
Does that means that such a key command does not exists?
Old 11-28-2009, 07:28 PM
Pro Tools OS X Shortcuts Guide has the answer.
filosofem
Old 11-28-2009, 07:36 PM
nod25 nod25 is offline
On Mac? Try Qwikn.
Why do people keep running over a string a dozen times with their vacuum cleaner, then reach down, pick it up, examine it, then put it down to give the vacuum one more chance?
Old 11-28-2009, 07:40 PM
filosofem
Well... not for this one it seems.
If I ask it's because it's not listed in the reference guide.
Old 11-28-2009, 07:42 PM
Originally Posted by nod25 View Post
On Mac? Try Qwikn.
It's not listed in the reference guide so Qwickn can't find it either.
Old 11-28-2009, 07:43 PM
Reference Guide? Bye.
filosofem
Old 11-28-2009, 07:47 PM
filosofem
Yes, Pro Tools Mac Shortcuts Version 8.0, in the help menu... you know?
What's wrong with my question??
Old 11-28-2009, 07:57 PM
You're using Shortcuts Guide and Reference Guide interchangeably.
Not the same.
Old 11-28-2009, 08:00 PM
Not the same.
Where can i find the shortcuts guide please?
It is not listed in the HELP -> Keyboard shorcuts file
And
it is not listed also in the HELP -> Pro tools Reference Guide
Again, please, anyone knows what's the key command to zoom in and out all the tracks in the arrange window the same way as when you click on the + and - signs under the vertical scroll bar?
Thanks for your help!
Vertical zoom to show default waveform height (Audio) with D-Command ? Hanswurstlsepp ICON & C|24 0 06-30-2011 03:55 AM
Individual Vertical Zoom Bug ev33 Pro Tools TDM Systems (Mac) 2 06-12-2009 01:22 PM
> Region Vertical Zoom Howardk Pro Tools TDM Systems (Mac) 3 12-23-2006 11:16 AM
Re: Vertical Zoom Key Command filosofem 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 11 07-05-2005 08:44 PM
DEFAULT VERTICAL ZOOM travista00 Pro Tools TDM Systems (Mac) 4 10-12-2003 10:47 AM
