#41
Re: Structure Free won't load
Also, does anyone have Metulski's instructions for Windows XP? That might be helpful... Thanks, Brett |
#42
Installing the newest PACE drivers didin't help either, but thanks for the suggestion... Anything else to try? At this point, it almost seems easier to just not use Structure until Digi fixes this...
#43
I also had the same problem.. stuck on structure
XP pro SP3, AMD phenom 3-core, 4 G ram, protools m powered 8cs3, m audio projectmix I/O, model Aspire M3201 (originally a vista 64 bit, but have xp pro 32bit as dualboot.... vista kinda sucks ) I removed IE8, I did the DEP fix, I removed the creative music kit, turned firewall off, loaded latest PACE.. and now it gets stuck on the VariFi plugin... It looks like it always get stuck on the last plugin it has to load. I tries removing all the plugins but then it only says 'loading plugins'... and gets stuck Also removed my firefox 3.0.5 (ashame). It is ashame that I must do so much to get a expensive piece of software (to me it is) running. I installed my old cubase 3... no problem what so ever. I have PT8 for two weeks now and it still won't work..... grrr anybody know what the problem might be, before I just give PT away and save money for cubase 5? |
#44
Just wanted to let people know, that I had the same problem and tried quite a few possible fixes (clean Windows install, Firewall disable, iLok update etc) but found that indeed, it was IE8 that stopped it from working somehow, uninstalling it from the Add/remove programs menu made PT8 work.
Thanks to the people who suggested this. Phew. Andreas |
#45
Yea, but what about those of us who don't even have IE8 isntalled in the first place? What are we supposed to do? Can anyone from Digi comment on this? Has there been any progress on a fix for this issue?
#46
You could also try deleting your cookies folder for any browsers you currently have installed. You're absolutely, positively sure you don't have IE8 installed? Your description is so much like the IE8 problem it's difficult to say what else it could be. Do you have the latest version of the Structure plug-in installed? |
#47
My XP came with IE8 standard installed... maybe that's why it wasn't in my add/remove programs. Removing it from dos didn't seem to work either, so I removed it from the program files folder.
Is it possible that there is something left in my system folder? I installed IE7 (download from MS), and it doesnt start up. When I received automatic updates, it did say IE8 in the update I will try to download a different version of XP, wich has IE7 installed in it and SP2. Is there a certain version of .NET that has to be installed? |
#48
#49
Most probably knew, but if you first installed IE8 and after that SP3, you cant remove IE8 without first uninstalling SP3. Then remove IE8 and reinstall SP3.
#50
Pro tools runs fine so far.. still have to check out the plug ins, virt instruments etc and I have to update to cs3.. but I HOPE that doesnt give any problems. One thing: You have to install the driver first for de Ilok, it aint just plug and pray Hope it keeps running interface looks cool |
Structure Free unable to load homemade files from Structure 1.0 | tuchel | Virtual Instruments | 0 | 04-26-2013 09:10 AM |
iLok problems for structure...reverted to structure free | thisistruth | Pro Tools 9 | 4 | 12-07-2011 08:04 AM |
When I loaded Structure from VIRT pack, Structure Free menu still there. | dl0banter | Virtual Instruments | 2 | 06-12-2011 02:23 AM |
Structure Free is taking forever to browse & load up samples | QPro5-AM | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 01-02-2010 06:32 AM |
