Buffer size error -9092 still cannot fix
Hi everyone there, I just upgrade my PC from pentium 4 to a Core 2 duo CPU
I was using the same operating system and pro tools runs without problem before but after changing my CPU and mainboard, I just cannot playback any audio in pro tools. (buffer size error -9092) I am using Pro tools LE 7.3.1 and already update the cs6 patch, with windows xp KB 896256 hotfix installed, disabled all USB / Firewire / Network device, and I have also followed the steps in General Troubleshooting - Pro Tools 6 & 7 Win XP for THREE times already. The problem just still here... I can't playback any audio with the error keeps popping up. I hope somebody can help me about this, the following is my computer detail MANY Thanks By the way i wonder if this problem will solve by upgrading to 7.4?... if it does I will purchase 7.4 and Vista immediately for any cost...@@ SiSoftware Sandra Processor Model : Intel(R) Core(TM)2 Duo CPU E8400 @ 3.00GHz Speed : 3GHz Cores per Processor : 2 Unit(s) Threads per Core : 1 Unit(s) Type : Dual-Core Internal Data Cache : 2x 32kB, Synchronous, Write-Thru, 8-way, Inclusive, 64 byte line size L2 On-board Cache : 6MB, ECC, Synchronous, ATC, 24-way, Inclusive, 64 byte line size, 2 threads sharing System System : Gigabyte Technology Co., Ltd. P35-DS3L Mainboard : Gigabyte Technology Co., Ltd. P35-DS3L Bus(es) : PCI PCIe IMB USB FireWire/1394 i2c/SMBus Multi-Processor (MP) Support : 1 Processor(s) Multi-Processor Advanced PIC (APIC) : Yes System BIOS : Award Software International, Inc. 255.255 Total Memory : 3.00GB DDR3 Chipset 1 Model : Giga-Byte (Bearlake) Processor to I/O Controller Front Side Bus Speed : 4x 333MHz (1.33GHz) Total Memory : 2GB DDR3 Memory Bus Speed : 2x 400MHz (800MHz) Video System Monitor/Panel : 隨插即用監視器 Adapter : NVIDIA GeForce 9600 GT Physical Storage Devices ST3120022A 120GB (ATA100, 2MB Cache) : 111.79GB ST3250820AS 250GB (SATA300, NCQ, 8MB Cache) : 232.88GB (C:) HL-DT-ST DVDRAM GSA-4163B (ATAPI33, 40x CD-R, 40x CD-W, 5x DVD-R, 5x DVD-W, 2MB Cache) : N/A (E:) Logical Storage Devices Hard Disk (C:) : 232.88GB (226.90GB, 97% Free Space) (NTFS) @ ST3250820AS 250GB (SATA300, NCQ, 8MB Cache) CD-ROM/DVD (E:) : N/A @ HL-DT-ST DVDRAM GSA-4163B (ATAPI33, 40x CD-R, 40x CD-W, 5x DVD-R, 5x DVD-W, 2MB Cache) 3.5" 1.44MB (A:) : N/A @ ST3120022A 120GB (ATA100, 2MB Cache) DateBase (D:) : 111.79GB (36.34GB, 33% Free Space) (NTFS) @ ST3120022A 120GB (ATA100, 2MB Cache) Peripherals Serial/Parallel Port(s) : 1 COM / 1 LPT USB Controller/Hub : Standard Universal PCI to USB Host Controller USB Controller/Hub : Standard Universal PCI to USB Host Controller USB Controller/Hub : Standard Universal PCI to USB Host Controller USB Controller/Hub : Standard Universal PCI to USB Host Controller USB Controller/Hub : Standard Universal PCI to USB Host Controller USB Controller/Hub : Standard Universal PCI to USB Host Controller USB Controller/Hub : USB Root Hub USB Controller/Hub : USB Root Hub USB Controller/Hub : USB Root Hub USB Controller/Hub : USB Root Hub USB Controller/Hub : USB Root Hub USB Controller/Hub : USB Root Hub USB Controller/Hub : USB Composite Device USB Controller/Hub : USB Composite Device USB Controller/Hub : Generic USB Hub FireWire/1394 Controller/Hub : VIA OHCI Compliant IEEE 1394 Host Controller Keyboard : HID Keyboard Device Keyboard : HID Keyboard Device Mouse : HID-compliant mouse Human Interface : HID-compliant device Human Interface : HID-compliant device Human Interface : 具 HID 功能的消費者控制裝置 Human Interface : USB 人性化介面裝置 Human Interface : USB 人性化介面裝置 Human Interface : USB 人性化介面裝置 Human Interface : USB 人性化介面裝置 Power Management Mains (AC) Line Status : On-Line Operating System(s) Windows System : Microsoft Windows XP (2002) Professional 5.01.2600 (Service Pack 2) Platform Compliance : Win32 x86 Network Services Network Drivers Enabled : No |
Re: Buffer size error -9092 still cannot fix
OK first; did you just plugin the same disk that had your original operating system on it? Or did you actually do a fresh Windows install after the motherboard and CPU upgrade? (hint: you should have done the fresh install)
Next, which Digidesign hardware are you using? The reason that I ask is that if it is any one of the firewire interfaces (002/002R, 003/003R, MBox2Pro) then this is a problem: Quote:
Which drive are you using for your sessions? The SATA or the ATA? (C or D?)
Thanks for the reply
1 - OK first; did you just plugin the same disk that had your original operating system on it? Or did you actually do a fresh Windows install after the motherboard and CPU upgrade? (hint: you should have done the fresh install) -I did a fresh Windows installation 2 - Next, which Digidesign hardware are you using? The reason that I ask is that if it is any one of the firewire interfaces (002/002R, 003/003R, MBox2Pro) then this is a problem: -I am using Mbox2Pro 3 - Quote: FireWire/1394 Controller/Hub : VIA OHCI Compliant IEEE 1394 Host Controller Via firewire controllers are known to cause conflicts. Definitely recommended that you use one of the Qualified Firewire cards. - I was using this firewire card before my computer upgrade and it works just fine, maybe capability problem to my new mainboard?? 4 - Which drive are you using for your sessions? The SATA or the ATA? (C or D?) - I use C: (SATA) for the sessions, I have tried to use D: for session but it saids its not a proper audio playback / recording drive. Thanks for helping~ |
The VIA firewire chip is still an issue. Even if it worked in your other computer, they have been known to be troublesome on some systems.
The dreaded H/W Buffer Size (Error 9092) message... | benwplj | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 10 | 05-05-2011 12:43 PM |
9092 error H/W buffer size | Murt | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 22 | 04-22-2008 11:18 AM |
Increase H/W Buffer Size - Error 9092 | rainmaker | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 10 | 08-09-2007 09:35 AM |
Still getting error 9092 & 9093: "increase HW buffer size" | pribb1 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 22 | 07-07-2007 10:36 AM |
Return of the Buffer Size Error - Part III -9092 | DiAngelo | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 18 | 11-15-2005 06:30 AM |
