Old 12-06-2007, 07:04 PM
davegibbon davegibbon is offline
Default Saving Xpand! patches
Hi there,
For the life of me, I can't figure out to save patches that I create in Xpand! For example, I would like to have a drum set up, where the kick, snare and tom/hats selector is already loaded, instead of calling them up every time.
Thanks in advance.
Dave
Old 12-06-2007, 07:12 PM
DonaldM's Avatar
DonaldM DonaldM is offline
Default Re: Saving Xpand! patches
There is no way to save patches in Xpand. The editing features you can use with it are only for the session in which you use it. If you save the Session, then whatever configuration you had in Xpand will be saved along with it. But, you can't save it within Xpand itself.
One workaround is to create a session and call up Xpand in an instrument and configure it how you like. Save the session. Then, if you want to use it in a different session, bring up the saved one, and re-save under a new name for the new session.
"Never believe anything you hear in a song." Tyrion Lannister, Game of Thrones
Owner: Dragon Rock Productions LLC
Old 12-06-2007, 07:30 PM
Dave, use 'Save Settings As' - Settings Menu: Chapter 29 of your Pro Tools Reference Guide - Plug-in and Hardware Inserts - The Plug-in Window. And either set your Settings Preferences to the 'Root Settings folder' or your 'Session folder' - also found in the same chapter - The Settings Menu.
filosofem
Aaron Mulqueen - 001 HD Native
Old 12-07-2007, 06:32 AM
French links French links is offline
Yep! Use the Save settings as... in the RTAS Window (just above the Xpand module).After you can even load it without browsing your folder to find those patches, click on the "Factory preset" pop-up and your patches should be in this latter.
xpand 2 and PT 8 no patches come up porkipine 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 10-15-2009 08:23 PM
Saving structure patches in bulk suicune Pro Tools TDM Systems (Mac) 4 04-27-2009 11:52 AM
Saving POD Patches In LE 7.3 rkaynan 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 09-29-2007 10:02 PM
RTAS Trilogy saving Patches batchmister1 Pro Tools M-Powered (Win) 1 02-01-2006 06:19 AM
Saving Patches in PT Hardnox MIDI 0 10-28-2001 06:32 PM
