Latency with 003
I know there is probably an easy solution for this, but I just can't figure it out. How do I get rid of the latency when recording instruments or vocals through the 003? It's pretty bad and I have no clue. Thanks.
Mac G5 dual 1.8 - 2.5 Gb Ram - PT7.3 - Digi003 |
Re: Latency with 003
Read up on Latency in the manual, and you'll find two ways: Lower H/W buffer size in the Playback Engine under "setup" menu. This will lower latency and allow use of the plug-ins on the track, but will not completely remove all latency. Use "low latency monitoring" under "options" menu. This is real close, but will mute the plug-ins (a cause of latency). Good luck, study that manual! Tony
Thousands in Computers, Software & Plug-ins...? *kinda ok* Studio on 400 acre farm? *priceless!* |
Thanks!
Automation latency when using plugins that have long latency | pyrodave | Pro Tools 11 | 2 | 01-27-2014 11:22 AM |
omni/native latency vs mbox pro latency | chrisdee | Pro Tools HDX & HD Native Systems (Win) | 34 | 03-30-2012 07:24 AM |
Latency Issues - changing latency has no effect | Kippa-Dee | Pro Tools M-Powered (Win) | 1 | 07-15-2010 08:39 PM |
Piano VI's- Latency Latency!! | MARVINBASS | Virtual Instruments | 5 | 04-27-2006 01:09 AM |
Unity DS-1 and Latency... Anyone else feel the latency makes the Plugin unusable? | Mt.Everest | Pro Tools TDM Systems (Mac) | 7 | 08-26-2001 04:53 PM |
