Increase H/W Buffer Size - Error 9092
I am unable to record or playback anything. Everytime I go to record a track, I get an error message - "The operating system held off interrupts for too long. If this occurs often, try increasing the "H/W Buffer Size" in the Playback Engine Dialog. (-9092)"
I spoke to the vendor, who suggested I use the Amnesty Upgrade, which I did. I upgraded from 7.1.2 to 7.3, which has an option to "ignore error during recording and playback" - Now I don't get the error message, but instead a message that shows "Problem detected with audio clock. Check that your clock source and sample rate are correct." Can someone please help....? Thanks in advance. |
Re: Increase H/W Buffer Size - Error 9092
We need a lot more info if we are to help. First thing I would check is to verify you are running your hard drives in DMA mode and NOT PIO mode. You do have 2 hard drives, right? You did do the required tweaks in the Getting Started Guide? Did you verify that your computer is compatible?
You should start with the steps in the Win XP/ Pro Tools 6.x/7.x General Troubleshooting thread and post specific info on your system per the info on that thread if you're unable to resolve the problem.
You may want to look at the Help us help you thread as well. |
Here are the details I have found. If there is anything else, please let me know.
System: Microsoft Windows XP Professional Version 2002 Service Pack 2 Computer: Intel Core 2 CPU 6400 @ 2.13Ghz 2.00GB RAM Chipset: Intel(R) G965 Express Chipset Chipset Components I/O Controller: Intel(R) 82801HB/HR I/O controller hub (ICH8/ICH8R) - IDE ATA/ATAPI controllers: Intel ICH8 2 port Serial ATA Storage Controller - 2825 Intel ICH8 4 port Serial ATA Storage Controller - 2820 - System devices Intel 82801 PCI Bridge - 244E Intel ICH8 Family PCI Express Root Port 1 - 283F Intel ICH8 Family PCI Express Root Port 4 - 2845 Intel ICH8 Family PCI Express Root Port 5 - 2847 Intel ICH8 Family SMBus controller - 283E Intel ICH8ICH8R Family LPC Interface Controller - 2810 Intel P965/G965 PCI Express Root Port - 29A1 Intel P965/G965 Processor to I/O controller - 29A0 |
The information I usually want to see is the hard drives. Usually this error shows up when people are only using one hard drive or recording to the system drive. Digidesign recommends recording to a physically separate 7200 RPM hard drive (not a separate partition). IF the second hard drive is external, it should be firewire and not USB.
Obsidian Dragon
MacbookPro14,3 - Intel Core i7 3.1 GHz, 16 GB MacOS 13.6.6 running Protools 2024.3.1 Mac Studio M1Max - 64GB MacOS 14.4.1 running Protools 2024.3.1 |
I have been using an external hard-drive, as I had read that this was recommended, however, it is connected via USB. I have organised to install a 2nd hard-drive in the next few days, so hopefully that will fix the problem... If it doesn't, what is the next thing I should look at...??? C |
There are many things to troubleshoot a problem listed in the Win XP/ Pro Tools 6.x/7.x General Troubleshooting sticky thread at the top of this forum. Let's start at the obious one with the USB hard drive and see how that works first.
Obsidian Dragon
I don't think the USB will work at all.
I was using a Lacie HD with the Oxford 011 chipset with my 002 and it worked great. Good Luck |
That is my opinion also. A few users have been able to use USB2.0 drives but in general it is not recommended for Protools. Protools need a sustained throughput to stream the digital audio for multitrack applications. USB can handle bursts of data but can not sustain the throughput to support this demand.
Obsidian Dragon
I have installed a new internal hard-drive into my computer, and am still coming up with the same error messages... - Audio Processing is conflicting with other CPU tasks. If this occurs often, reducing the "H/W Buffer Size" in the Playback Engine Dialog may help prevent the problem. (-9129) When I reduce the buffer size, I then get the error - The operating system held off on interrupts too long. If this occurs, try increasing the "H/W Buffer Size" in the Playback Engine Dialog. (-9092) I am beginning to think this is WAY TOO HARD. Does everyone have this kind of drama when trying to use this system... I'm beginning to think it's junk...!!! C |
increase H/W buffer size error | dgrim | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 17 | 07-08-2009 04:50 PM |
9092 error H/W buffer size | Murt | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 22 | 04-22-2008 11:18 AM |
Buffer size error -9092 still cannot fix | AuAu | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 03-28-2008 08:55 PM |
Help! "Increase Buffer size" error | therigaletto | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 02-17-2008 05:25 PM |
Still getting error 9092 & 9093: "increase HW buffer size" | pribb1 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 22 | 07-07-2007 10:36 AM |
