Return of the Buffer Size Error - Part III -9092
First off, thank you to the people who take the time to read this post and the other posts I have had in the past.
I bought an MBox2 and installed Pro Tools LE 6.8.1 (some weeks ago). I noticed something that since then hasn't been solved: I can't monitor an input with HW buffer size at 128, because I hear frequent sound cuts, and whenever I try to play/record at that value, I get a maximum of 2 seconds of playback/record until it gives the error message: "The operatin system held off interrupts for too long. If this occurs, try increasing the "H/W buffer size" in the Playback Engine Dialog. (-9092) " "Bummer", I thought the first time. I select 256 and it plays/records!... For 2 minutes aprox.... This is when I realised it couldn't be normal. I thought it was because I was using the internal laptop Hard drive, and I bought a Digidesign supported enclosure + 250 GB Hitachi hard drive (7200 RPM, 8 MB cache) and created a new session to run on that drive. Nothing changed. The same error. Since then I've been asking questions in the DUC, I turned off all services and startup programs, all unnecessary hardware (I mean ALL), trashed DAE Prefs, removed plug-ins, created new sessions without Mac/PC compatibility, went to the Digi answerbase and did everything I found about this error. I even reinstalled Pro Tools. Nothing. It just stays there, reacting the same way everytime, expecting me to monitor/record at 512 to be able record a 4 or 5 minute take. And that's not what I spent 800 dollars for (Mbox2 + external HD). I've been having a lot of personal problems and I'm moving to the US soon, and I NEED to get one more song pre-produced before I go, so this is killing me slowly and I need help. C'mon this can't be so hard to solve. Digi has good technicians right? =( Laptop: Acer Aspire 1694 WLMi My present Sandra system summary is in a post below. Please help me. Thank you in advance. Bruno DiAngelo ==== |
Re: Return of the Buffer Size Error - Part III -90
SiSoftware Sandra
System Host Name : User : Domain : Processor Model : Intel(R) Pentium(R) M processor 2.00GHz Speed : 2.00GHz Performance Rating : PR2394 (estimated) Cores per Processor : 1 Unit(s) Threads per Core : 1 Unit(s) Type : Mobile Internal Data Cache : 32kB Synchronous, Write-Back, 8-way set, 64 byte line size L2 On-board Cache : 2MB ECC Synchronous, ATC, 8-way set, 64 byte line size Mainboard Bus(es) : ISA PCI PCIe IMB CardBus USB FireWire/1394 i2c/SMBus MP Support : No MP APIC : Yes System BIOS : AT/AT COMPATIBLE Total Memory : 1023MB DDR2-SDRAM Chipset 1 Model : Acer Inc 82915PM/GM/GMS, 82910GML Host Bridge Front Side Bus Speed : 4x 133MHz (532MHz data rate) Total Memory : 1GB DDR2-SDRAM Memory Bus Speed : 4x 99MHz (396MHz data rate) Video System Monitor/Panel : Default Monitor Monitor/Panel : Default Monitor Monitor/Panel : Default Monitor Monitor/Panel : Plug and Play Monitor Adapter : ATI MOBILITY RADEON X700 Physical Storage Devices Hard Disk : ST9100822A (93GB) Hard Disk : Macpower OXFORD IDE Device 1 IEEE 1394 SBP2 Device CD-ROM/DVD : MAT****A UJ-845D (CD 24X Rd, 24X Wr) (DVD 3X Rd, 3X Wr) Logical Storage Devices 1-winxp (C:) : 14GB (6.2GB, 45% Free Space) (NTFS) 1-prog (D:) : 20GB (12GB, 59% Free Space) (NTFS) 1-data (E:) : 60GB (35GB, 58% Free Space) (NTFS) Pro tools le (G:) : 316MB (CDFS) 2-protools (H:) : 59GB (42GB, 71% Free Space) (NTFS) 2-data (I:) : 99GB (56GB, 57% Free Space) (NTFS) 2-storage (J:) : 61GB (46GB, 76% Free Space) (NTFS) 2-transfer (K:) : 15GB (15GB, 100% Free Space) (FAT32) Peripherals USB Controller/Hub : Intel(R) 82801FB/FBM USB Universal Host Controller - 2658 USB Controller/Hub : Intel(R) 82801FB/FBM USB Universal Host Controller - 2659 USB Controller/Hub : Intel(R) 82801FB/FBM USB Universal Host Controller - 265A USB Controller/Hub : Intel(R) 82801FB/FBM USB Universal Host Controller - 265B USB Controller/Hub : Intel(R) 82801FB/FBM USB2 Enhanced Host Controller - 265C USB Controller/Hub : USB Root Hub USB Controller/Hub : USB Root Hub USB Controller/Hub : USB Root Hub USB Controller/Hub : USB Root Hub USB Controller/Hub : USB Root Hub USB Controller/Hub : USB Composite Device USB Controller/Hub : USB Composite Device USB Controller/Hub : Digidesign Mbox 2 Firmware Updater USB Controller/Hub : Digidesign Mbox 2 Firmware Updater FireWire/1394 Controller/Hub : Texas Instruments OHCI Compliant IEEE 1394 Host Controller PCMCIA/CardBus Controller : Texas Instruments PCIxx21/x515 Cardbus Controller Infrared Device : IrDA Fast Infrared Port Keyboard : Standard 101/102-Key or Microsoft Natural PS/2 Keyboard Mouse : PS/2 Compatible Mouse Mouse : HID-compliant mouse Mouse : HID-compliant mouse Human Interface : USB Human Interface Device Human Interface : USB Human Interface Device MultiMedia Device(s) Device : Conexant AC-Link Audio Communication Device(s) Device : SoftV92 Data Fax Modem with SmartCP Printers and Faxes Model : Microsoft Office Document Image Writer Model : Macromedia FlashPaper Model : Adobe PDF Power Management AC Line Status : On-Line Battery No 1 : 100% Operating System(s) Windows System : Microsoft Windows XP/2002 Professional (Win32 x86) 5.01.2600 (Service Pack 2) Network Services Adapter : Intel(R) PRO/Wireless 2200BG Network Connection ... |
Re: Return of the Buffer Size Error - Part III -9092
I dont have anymore problems with PT because I stopped using that piece of SHYT...I use the mbox 2 with nuendo 2 and guess what? Is like butter...I tracked 20 songs in 4 days compared to 1 in PT...Why they have all those stupid tools is beyond me...Do a search for buffer size error and you will find that you are not the only one having those issues...I have a 3.0 pentium 4 and 2 gigs of ram but I cant track for 5 minutes in PT...what a piece of crap. Digi, get your minds correct...
sincerely yours |
Please Digidesign, help me. I don't want to return to that dark place called Cubase. |
Hello? DigiTechSupt? Anyone?
The only thing I haven't tried is installing Pro Tools 7. Will I have to reinstall all plug-ins? Should I do it? SOmething tells me it won't solve anything. Has Digidesign solved incompatibility problems or something like this, in version 7? |
I wouldn't say that Pro Tools isn't well written. It's the strict requirement that the software has of not dropping samples. Yeah, I thought it was great when I could record for several minutes in Samplitude using ASIO but I had hundreds of dropped samples. I fixed up the hardware configuration and I have no problems anymore.
What did you do?
To also address your post, to solve my problems, I disabled the battery in the hardware profile. That eliminated the same problem that you are experiencing. BTW, I am recording to my system drive 16+ tracks simultaneously with plug-ins and all at 64 sample latency and not a hiccup. I have a 1.8Ghz Pentium M with 1024MB of RAM.
There was one point in time that somehow the computer got screwy again even though the batter was disabled. At that point, I removed the "ACPI-Compliant Computer." This causes all of your devices to disable and get redetected on start up. |
In two cases, disabling the "Microsoft ACPI-Compliant Control Method Battery" in the device manager solved the problem.
1) Go to Windows Control Panel. 2) Click on "System". 3) Click on "Device Manager" 4) Expand "Batteries" to view ACPI driver. Right Click "Microsoft ACPI-Compliant Control Method Battery" and select Disable to disable the driver If that doesn't do it, can you be more specific about what you have and have not done as far as other tweaks go? Did you disable all network devices, including any wireless controllers? Did you use MSCONFIG to disable all startup items? Are all background/system utilities turned off, etc? |
When did your computer got screwy again? What did you do to solve it? I didn't understand that part. Do I have to DISABLE the battery or I can just remove it from the notebook? Please keep in touch! I think I'm deeply in love with you! |
The dreaded H/W Buffer Size (Error 9092) message... | benwplj | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 10 | 05-05-2011 12:43 PM |
9092 error H/W buffer size | Murt | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 22 | 04-22-2008 11:18 AM |
Buffer size error -9092 still cannot fix | AuAu | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 03-28-2008 08:55 PM |
Increase H/W Buffer Size - Error 9092 | rainmaker | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 10 | 08-09-2007 09:35 AM |
Still getting error 9092 & 9093: "increase HW buffer size" | pribb1 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 22 | 07-07-2007 10:36 AM |
