  #21
Old 01-26-2022, 07:32 AM
cebolao cebolao is offline
Default Re: EUCON 21.10.1 Released
so, any news about this bug?
it's kind of a show stopper when mixing dialogs for example
  #22
Old 01-28-2022, 09:51 AM
EddieJones's Avatar
I can't seem to repro this. What do you have this setting set to? Open Windows on Workstations when knobs assigned from Daw Click?
  #23
Old 01-28-2022, 01:14 PM
PM sent
  #24
Old 02-10-2022, 06:27 AM
Plugins follow track selection seems to be broken in this release. (has been broken in earlier versions, then at some point worked, now seems to be broken again)
I press EQ on the S1. Channel strip pop up. I move selection to other track, EQ stays with the initial track.
Yes, "edit selection move up/down" is on.
Anything else I might be missing?
Thanks!
Frank.
  #25
Old 02-10-2022, 08:39 AM
EddieJones's Avatar
This is working for me, the fact you say it sometimes works points to a setting changing. Can you post an image of your General settings?
  #26
Old 02-10-2022, 01:23 PM
Thanks Eddie. Not working on 3 co-worker's rigs (running current EC and PT)"Sometimes" as in "it worked n older versions of EC in the past" but never worked in the current one for me.
Weird. I'll post a screen shot when I'm back in the morning.
Thanks
Frank.
  #27
Old 02-11-2022, 01:16 AM
Here are my settings. Tried all sorts of other combos but no luck so far. Not working for my 2 co-workers either. They are on Artists with and without iPad. I have an S1 with tablet. Also attached: Digi surround panner.
I also disconnected the tablet entirely to rule that out but no change.
https://www.filemail.com/d/tfzbrdgrbmperiq
  #28
Old 02-11-2022, 04:25 AM
OK, I figured it out. "open windows when knobs assigned..." needs to be set to Avid Control or channel mode knobs.
Confusing description but now the CS follows.
What's odd now is that the channel page will jump to the GROUP page when moving up and down the tracks in the session quickly. Might be a bug. Move up and down slowly it stays on the EQ page. Do it fast a couple of time it will jump to the group page at some point and stay there.
Thanks
Frank.
  #29
Old 02-24-2022, 06:42 PM
Lunazen Lunazen is offline
Attempting to install EUCON_WorkstationUnifiedInstallMac_2021_10_1_29 to use with an iPad.
Unable to install. Every time I get a message "The Installation Failed" I have uninstalled (with prefs) and reinstalled, re-downloaded and still "The Installation Failed".
MacBook Pro, OS 10.14.6 (18G9323)
Current PT software
Apologies if I should post this elsewhere - been a member since 2011, user since 1996, but never posted myself!
Thanks in advance for any help.
  #30
Old 02-24-2022, 09:18 PM
EddieJones's Avatar
Current PT software
When is it failing? it sound like it is installing as you are then uninstalling?
EUCON 20.5.0 released EddieJones Artist Series 29 06-05-2020 06:16 AM
EUCON 20.6.1 released EddieJones Avid S4/S6 0 05-21-2020 10:30 AM
EUCON 20.1.0 Released EddieJones Avid S1, S3, Dock and Control App 44 05-08-2020 11:59 PM
EUCON 20.1.0 Released EddieJones Avid S4/S6 11 03-09-2020 11:35 AM
EUCON 20.1.0 Released EddieJones Artist Series 2 03-03-2020 07:31 AM
