  #111
Old 04-28-2016, 01:09 AM
Pete Gates Pete Gates is offline
Default Re: New PT Prefs helper
If you can't even get that far go to "~/Library/Application Support/PT Prefs" and delete that folder and everything in it ~ means /Users/your username
  #112
Old 04-28-2016, 01:45 AM
Looking at this now, nothing leaping out at me yet. Did you have the backup path set to somewhere other than the default?
Pete
  #113
Old 04-28-2016, 02:12 AM
1.6.13 up which May fix this problem
  #114
Old 04-29-2016, 01:16 AM
Originally Posted by polyh3dron View Post
Someone had the bright idea of changing the name of the boot drive on our systems, and now PT Prefs crashes on launch for me, since it can't find the folders I've set for it to use. Where can I find the PT Prefs config file so I can trash it and start fresh? I already tried deleting and redownloading the program and that didn't do the trick.
Fixed in 1.6.14 - please test.
Pete
  #115
Old 05-04-2016, 12:11 PM
polyh3dron polyh3dron is offline
Thanks Pete, your update fixed my issue!
  #116
Old 05-04-2016, 12:25 PM
Excellent.
Pete
  #117
Old 05-15-2016, 03:42 PM
Peter Baird's Avatar
Peter Baird Peter Baird is offline
Hey, thanks a bunch, Pete! Melodyne wasn't showing up under ReWire and your app fixed it.
Peter
Gypsy: PT Ultimate 2019.5, 12-core Mac Pro 3.46Ghz 64GB OS 10.14.5, HD Native, HD OMNI, 2 Artist Mix, EUCON 18.3, Presonus 32R, Studio One 4.5.1, Quad Eight preamps, Neve 3201 EQs, 2 LA-4s, Malone Design Works desk
Laptop: 10.13.6 MacBook Pro 2.8 Core i7, 16G, PT 19.5 Live 9
www.remotewest.com
@RemoteWest
  #118
Old 05-16-2016, 06:27 PM
timsound2006 timsound2006 is offline
Hey Pete,
Thanks for the wonderful program - used it many times over the years. Just recently I ran it and it seems to have confused PT 12.5 about my Speakerphone authorization. Now PT says Speakerphone failed to load because it is not a valid 64 bit AAX plugin. I've reinstalled the plugin repeatedly, and updated iLok manager, with no success. Do you have any ideas? I've heard there is a PT file somewhere of "valid" plugins, that PT12 uses to load faster. I assume this file was deleted when I ran PT prefs, but the question is how to get PT to rebuild this list properly? Thanks in advance for any help.
Tim
OSX 10.9.5, PT 12.5
  #119
Old 05-17-2016, 02:51 AM
Blues Bird Blues Bird is offline
hey Pete,
Thanks for your great little app. It is a life saver.
  #120
Old 05-17-2016, 01:56 PM
Firstly the easy one, glad people are finding it useful.
Tim, I have Speakerphone on my system and I'm on 12.5 and actually had to trash prefs this morning and didn't get this problem. Yes, there is a cached list of plugins that if you trash all prefs will get deleted. Pro Tools scans and rebuilds that list when it is next run - you should notice Pro Tools opening significantly slower first time as it scans them. Do you definitely have the latest installer? You don't have an old AAX 32 bit installer? If you run PT Prefs and go to the plugins tab and scan just AAX plugins what version does it show for Speakerphone?
Cheers,
Pete
Updated: ProTools Prefs & Database Helper JC925602 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 06-25-2009 05:35 PM
updated: ProTools Prefs & Database Helper JC925602 Pro Tools M-Powered (Mac) 0 06-24-2009 12:48 PM
ProTools Prefs & Database Helper/le8 and 10.5.5 b mcgibney 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 01-23-2009 12:00 PM
ProTools Prefs & Database Helper meric 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 04-16-2007 11:50 PM
No Sound-help!! After deleting Digisetup, PT prefs and DAE prefs bigthinka9 Pro Tools TDM Systems (Mac) 6 10-24-2002 07:41 AM
