A couple of hot key questions...
I have lots and lots of tracks in my template...scroll is become very tedious. Is it possible to set up memory locators in the edit or mix window so tracks 1-12 can show up with a key command....then I enter another key command and it goes to 120-132?
Also is it possible to record enable the track below or above the currently selected track with a key command? Thank you!
PT 9.0.3 Windows 7 64 bit, 2x i7 PCs, 24GB, 3 SSD's, 5 HD's ....and a couple other toys. |
Re: A couple of hot key questions...
Not sure about the record enable question although I don't think it's possible. You can definitely set up Memory Locations to Show/Hide tracks. Look under the Windows menu in PT. If you're on a Mac, you can hit Command+5. If you set up a Memory Location for the number 1, you would hit on the numeric keypad period-1-period to access that location, whether it's a marker, track view, windows configuration etc...
Help Us Help You ______________________________________ Chris Pro Tools 2024.3 Focusrite LS56 Focusrite Pro40 (2) TC Electronic Studio Konnekt 48 Avid Artist Mix/Control Slate Digital VRS8 Analogue Tonebuss 24 Channel UAD-2 OCTO Core Accelerator UAD Volt 2 macOS 10.15.7 32 GB DDR4 RAM 4.01GHz Quad-Core Intel Core I7 NVIDIA GeForce GT 740 2 GB |
I'd rather not show/hide, I rather just automatically scroll down through the tracks to a particular section of my template. This isn't possible?
I use mix/edit groups to move around. If you click on the group ID in the groups list, the members of that group will be selected. I often follow that up with Ctrl+Command+Up arrow, and selected tracks will fit to window.
IHTH.
No, not the way you're describing.
Sounds good.
PT lover that sounds good I'll try that. One last thing lets say I selected a certain track in the Edit window and want to get to it really fast in the mix window. What is the hot key for that? I saw it in the key commands PDF 1 time and now can't find it.
Beautiful.
Ty
Couple Questions | Skeeter Joplin | Tips & Tricks | 3 | 03-01-2010 03:05 AM |
Couple of help questions | Brazen15 | Pro Tools M-Powered (Win) | 5 | 10-23-2007 12:54 PM |
Couple questions. | Don Geppert | ICON & C|24 | 5 | 10-05-2006 03:11 PM |
A couple questions | G_Bender | Tips & Tricks | 5 | 10-04-2005 08:15 AM |
6.4 to 6.7. A couple questions | dodo | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 01-10-2005 01:38 PM |
