Re: Chase SMPTE (LTC) with Motu 2408mk 3 or 828mk3
Jam sync is a method of regenerating damaged timecode. You don't need this in Pro Tools since it would be chasing first-generation MTC directly generated by the sync box.
In addition to all the good advice mentioned earlier, you might try setting the MOTU unit to use the incoming LTC from the tape deck as the audio clock source - I don't remember the exact phrasing of the MOTU menu selection (I used to have an 828 MkII), but extracting audio clock from the incoming TC should allow for PT to more accurately follow (via slewing of the PB sample rate) the minor tape speed variations of a simple, non-constant tension transport like the 80-8. This may help your problem of going progressively more out of sync as the playback progresses.
Good luck. Larry Upton LGUAudio |
Hey.
I've just got an 828mk3 and seem to be having problems with it syncing my fostex r8 tape machine to pro tools using it. I've gotten as far a recording the SMPTE timecode onto the tape but as I being playback and get the MOTU SMPTE reading software reading the tape loud 'pops' and 'clicks' begin which overwhelm all 8 tracks. I can see that the MOTU is trying to lock in with the tape but it just doesn't seem to want to. It seems to be having trouble with the tape for some reason. If I start the timecode generator and route it through the machine while on input mode, basically sending it back into itself in real time, it will then lock in. I've tried a number of things...recording the timecode onto tape at different levels, turning on/off the noise reduction, recording it onto different channel but none seem to be helping. I've read bits about the MOTU's sometimes making weird noises to I tried downloading the new drivers but they're not helped either. Here's what it sounds like: http://www.sendspace.com/file/d2sztf Does anyone have any suggestions? All the best Martin |
Beware the 828mk3 will not lock to incoming ltc resolved to wordclock. You can only lock to ltc when you are on internal.
This is really [bleep][bleep][bleep][bleep][bleep] because really there are only very rare situations where you want to chase timecode and be running on internal, so what's the point of having an ltc input?! |
hi james
i'm little unclear about your reply. if i'm on internal doesn't that just take the MOTU reading the SMPTE from tape totally out of the equation? also, do you think i need something that can resolve to word clock? i've been told from the MOTU distributors at music track that i shouldn't need any more hardware. seeing as the moto will lock when the SMPTE output is fedback into it's input i still think the problem lies with how the timecode is being recorded onto or read from the tape machine. |
PT9 & Motu 828mk3 interface | FT13 | macOS | 0 | 12-23-2011 09:37 AM |
SMPTE connections options on the Motu 828mk3 | chrisdee | General Discussion | 2 | 04-30-2011 01:08 AM |
Any advice on best way to use 003 and MOTU 828mk3? | hwalker | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 06-27-2009 09:13 PM |
Macbook with MOTU 828Mk3 | Lizardpoint | Pro Tools M-Powered (Mac) | 2 | 03-28-2009 03:21 PM |
How does PT chase to MTC/SMPTE? | Chris Duncan | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 09-27-2001 11:54 AM |
